meth location
Old Nov 19, 2009 | 07:09 PM
jeepbeast's Avatar
meth location
i'm planning on running meth on my engine and wondering if it would make a difference if i am using the vortech elbow that has the dividers in it or should i get a trickflow without? would the dividers affect the distribution of the spray?
Old Nov 20, 2009 | 08:12 AM
RealQuick's Avatar
I got the TFS to avoid that situation. If ygo with a dual nozzle setup on the kit, then you can mount one nozzle per side.
Old Nov 20, 2009 | 08:53 AM
koolaid_kid's Avatar
Since you will be spraying a liquid into an area that was not designed for it, I would expect the dividers (baffles?) to affect the distribution. I would suggest a smooth elbow, such as the Trickflow.
Old Nov 21, 2009 | 07:35 AM
blown94's Avatar
i put mine in the plastic pressure side tube right b4 the elbow so it gets a chance to "swirl" a little and mix b4 the last turn.
Old Nov 22, 2009 | 02:02 PM
Kevin Blown 95 TA's Avatar
Me too. I have two there, and may put them in both sides of the vortech elbow when I make a custom outlet pipe if I ever get around to it. I think it'll work fine either way.
IndyZman
Oct 22, 2015 02:17 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
RobFlag
Aug 29, 2015 11:40 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
