Extreme Battery Drain, Checked all fuses, please help!!!!!
Old Nov 14, 2009 | 11:56 AM
350 HRSS's Avatar
Question Extreme Battery Drain, Checked all fuses, please help!!!!!
Here is my issue....for the past couple months I have been having a very bad battery drain. It has destroyed 1 Optima battery....
I have a free new replacement Optima, but this time, I have convinced myself to find the drain and stop putting it off. This has been a problem for about a year, the car isn't my DD, so it hasn't been a huge issue....
I have used a test light, in between the battery and negative cable, and that light is bright! I have pulled every fuse in the interior, and every fuse in both fuse boxes under the hood. That light has remained BRIGHT....it never dimmed, and I pulled all the fuses, twice! Is there another fuse box somewhere?
Also, when I hooked up the test light, there was a loud clicking in my dash box....I have read about people havin bad a BCM? And that it was in the glove box, is that true???
I also heard a clicking noise from the head light area, and unhooked the plug that is on the driver's side to keep the lights either up or down, and the clicking slowed a little....readjusted the test light, repeated it, and this time, nothing, just a bright light on the test light. But that light never went out, when I pulled ANY of the fuses....I haven't added anything electrical to this car...and the cam, headers, ect was done years ago....
SO...does anyone have a verdict? How do you find a drain on a car when you have pulled every fuse and the test light NEVER went out?!?!?! BTW, this is a 99 TA.
The drain is so bad, I could drive to work, get back in the car before I left (about 8 hours later) and it almost not want to crank!!!! What could it be???
Old Nov 14, 2009 | 12:57 PM
350 HRSS's Avatar
Here is another issue...
I went back out there, and did the test light again, it's bright and there is a clicking noise somewhere around my driver's side head light area. So, when I unplug the plug that powers the lights up and down, right next to the fuse boxes, and resume w/ the test light, the clicking goes away, and the test light comes on, but fades completely out in about 5 seconds.....I redid this test 4-5x, and get the same result everytime....
Is it something to do w/ my headlights???
Anyone?
Old Nov 14, 2009 | 01:04 PM
350 HRSS's Avatar
NOW, I just went back and checked it out w/ the test light again, and I am hearing a clicking under the glove box.....Can someone tell me how to get the BCM out? I have the glove box out, and see a black box, but can't figure out how to get the BCM out of there....I want to look at it, or replace it. What all is involved w/ that???
Sorry for all the posts, just tired of this, and need to get this car fixed.
Old Nov 14, 2009 | 02:18 PM
bluz28's Avatar
Try swapping some of the relays around that in the fuse boxes under the hood and see if that makes a difference. May be you have a bad relay, also do you know for sure that your battery is being charged by the alternator?
Old Nov 14, 2009 | 02:31 PM
350 HRSS's Avatar
I did replace the alternator today, along w/ the battery and an oil change....just took it down the road, and scanmaster said the battery was at 13.1-13.2 while driving. Just got back, and hooked the battery up to the charger to check the volts, it was sitting at 12.6. I did leave the headlight plug undone, and will check the voltage again in the morning to see if it has fallen at all....If it does drop bad, I will know something is eating it up, if it doesn't, I will know it's in that head light plug somewhere...right?
This is very annoying!!!
I did have a faint hope the alt. was going bad, since it's the factory one, maybe it was???
Old Nov 18, 2009 | 02:26 PM
Marc 85Z28's Avatar
Are you disconnecting the headlight motors?
Do the headlight motors work properly - do they go up and down OK without any grinding?
Try disconnecting the Headlamp Opening Door Actuator Control Module. It contains a several relays that could cause a battery drain. It is located in the engine compartment under the fuse panel, close to where you are hearing the noise.
Old Nov 21, 2009 | 08:46 AM
Chevyssoccer's Avatar
yeah, it sounds like you have a relay that is staying closed.
Old Nov 21, 2009 | 09:03 AM
MikeGyver's Avatar
Check how much current is being drawn with a miltimeter.
fpete1992
Dec 11, 2014 03:51 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
sleeperZ96BT
Jul 24, 2002 11:28 AM
