Not an LT1 Pulley?
Old Nov 3, 2009 | 08:09 PM
ponyackn's Avatar
Not an LT1 Pulley?
I bought a vortech 2.95 pulley from Summit.
http://images.search.yahoo.com/image...sigb=12g1md6rm
It has a long neck to it, like the one that shows in the picture, that pushes it out further than the original pulley that was on there. Therefore, it doesn't line up with the other pulley. Did I get the wrong model? Or can I just have the stem machined off? Anybody else experience this?
Old Nov 4, 2009 | 07:38 AM
jsetzer's Avatar
96 and 97 require a shorter hub because of the reluctor for the crank sensor.
93-95 had a longer style
I'm not for sure about cutting it down - I would ask vortech. You could always remove the reluctor too. I have done this on an obd1 conversion, and think you can take it out even with obd2.
Old Nov 4, 2009 | 08:20 AM
blown94's Avatar
hes talking about the actual s/c pulley, not the crank pulley. lt1's in general have different s/c pulleys because of the tight fit. i had to have my old powerdyne pulley machined to fit as well for the offset
Old Nov 4, 2009 | 08:51 AM
jsetzer's Avatar
Oops - there I go trying to help.
<--- Beltless boost
Old Nov 4, 2009 | 06:53 PM
ponyackn's Avatar
<--- Beltless boost
There ya go, rub it in
Thanks for the info guys. I guess I'll get this thing machined. Damn. I couldn't get vortech on the line and summit didn't know anymore than I did. The part number and description wasn't specific enough. I should've went to ASP for this one.
Old Nov 5, 2009 | 08:19 AM
97WS6SCharged's Avatar
Do the part numbers match? Summit could have made a mistake.
Old Nov 8, 2009 | 11:01 AM
ponyackn's Avatar
You are exactly right. Thanks for that, I checked the pn on the bag and sure enough, I was sent the wrong one. I don't know if they'll let me return it at this point, I'll check. But, I'll try to get it machined if they won't.
Old Nov 8, 2009 | 05:00 PM
Kevin Blown 95 TA's Avatar
I got sent the wrong one too, but I chucked it in a lathe at work and fixed. Wtithout a lathe, not sure what you could do.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Jason Short
Jan 19, 2015 06:34 PM
