Old 08-06-2009, 10:52 PM   #1
DAKMOR
DAKMOR's Avatar
18 gears, no biggie.
i think i can drive that after fiddling with the idea in my head.
to date, my third favorite car and driver article. article
__________________
Quote:
Originally Posted by mdenz3 View Post
If I had $75K... I would buy 75 old POS Camaros.[
TRYIN TO GET A 3RDGEN...WITHOUT A MULLET!!
DAKMOR is offline   Reply With Quote
Old 08-06-2009, 11:12 PM   #2
JakeRobb
Super Moderator
JakeRobb's Avatar
After reviewing that diagram, I still have no idea how to go about shifting gears with that transmission.
__________________
2002 NBM Camaro Z28 M6 - best ET 13.21, best MPH 108.9, best 60' 2.14 - 325hp/343tq - Lid, Corsa, SixSpeedsInc T56, Pro 5.0 w/ short stick, 17x9 wheels
1987 Buick Grand National - best ET 13.66, best MPH 101.5, best 60' 2.08 - 253hp/334tq - 93 chip, RJC, meth, Hooker catback, 160 t-stat, shift kit, no-hop bars
JakeRobb is offline   Reply With Quote
Old 08-06-2009, 11:14 PM   #3
sko_spo
mon-fri
__________________
1997 Z28 30th Anniversay 6 speed
Engine-CAI,TB-Bypass,LT4 Springs/Retainers/Locks,Crane Gold 1.6rr, LT4 KM,Hypertech Power Programmer
Exhaust- Jethot LTs, Hooker Y-pipe,Casper 02 sims, 3" Cutout , Magnaflow Muffler
Misc-Powercoated Intake Manifold,160deg T-stat,Chrome Valve Covers,Clear Corners
sko_spo is offline   Reply With Quote
Old 08-06-2009, 11:19 PM   #4
DAKMOR
DAKMOR's Avatar
Quote:
its simple, u start in LO or "0" gear in Range:L Splitter:L. then go to 1,2,3,4, then change Range to H and go 5,6,7,8. You can also use the Splitter to go between them for an extra 9 gears that may be required for more comfortable cruising/towing.
more like a 10 speed bike with a low and high front gear set actually. but the splitter is a bit of a mixup to be honest.
__________________
Old 08-06-2009, 11:21 PM   #5
T/A-Bob
Premium Member
T/A-Bob's Avatar
Why is the lowest gear called "lo" and not "1"?
__________________
'94 T/A LT1/A4. Arctic white with factory arctic white wheels, low spoiler. K&N FIPK, 3.42s, 1.6rrs, free mods, 160° stat/fans, Nitto 245/50-16 DRs. Best run: 13.683@100.39. 60'@1.990. New since that run: Corsa catback.
T/A-Bob is offline   Reply With Quote
Old 08-06-2009, 11:21 PM   #6
GrdLockV6
GrdLockV6's Avatar
Send a message via AIM to GrdLockV6
Looks like fun!
__________________
Kyle
Quote:
(6:37:35 PM) fuzzyblupenguins: haha
(6:37:46 PM) GrdLock: nothin but white girls for me
(6:37:54 PM) fuzzyblupenguins: yea me too :-P
GrdLockV6 is offline   Reply With Quote
Old 08-06-2009, 11:23 PM   #7
DAKMOR
DAKMOR's Avatar
my question, is why arent there automatics in these things yet,.
__________________
Old 08-06-2009, 11:26 PM   #8
Koz
Koz's Avatar
Send a message via AIM to Koz
From what I gather you start from a stop and your range selector is down (Lo), then you go from LO gear to 1st, 2nd, 3rd, 4th. I think in any of those gears, you can choose between H and L as well, so you can do Lo L, then Lo H, then 1 L, then 1 H...all the way up thru 4 H.
Now, if you want to shift into 5th, you move the range selector up (Hi) and shift into 5th. If you don't move the selector up, you'll shift back into first! And then you have the same H and L options as before.
I've never driven a truck or a vehicle with a trans that had more than 6 gears...so for those of you in the know, do you usually cycle through gears like that? Hitting the lo and hi for each gear? Or do you usually just pick one or the other while making your way through the gears?
__________________
'09 Cobalt SS
Koz is offline   Reply With Quote
Old 08-06-2009, 11:27 PM   #9
Koz
Koz's Avatar
Quote:
I believe some have automatics...perhaps they aren't as strong as manuals though.
__________________
'09 Cobalt SS
Old 08-06-2009, 11:41 PM   #10
Bayer-Z28
Bayer-Z28's Avatar
Send a message via AIM to Bayer-Z28 Send a message via MSN to Bayer-Z28 Send a message via Yahoo to Bayer-Z28
And...................
I've driven those before.. No big deal.... Yes, you just shift in the typical H pattern, but hit the splitter after you're thru 5th, then go back to the 1st position and grab 6th.
Quote:
Low is seriously a creeping gear. no faster than about walking speed. To get a VERY heavy load moving from a dead stop when first won't cut it.
And automatics are used in some models, but it's an option and it all depends on what the company specifies. If they are going to have drivers who possibly can't drive a manual, they will opt for the auto. Just imagine the heat that an auto would produce trying to move 200,000 lbs.
Those EF Trans' are triple counter shaft models. I've swapped them out before when I was working at a crane rental service back in 2001-2002. and the Clutch can have a double or triple disc clutch setup. The flywheel alone can weigh 200+lbs. We had a small 15ton truck crane in the yard when we had to pull those.. It was actually a very easy removal. Install can be difficult, though. It has bell housing bolts surrounding the entire mating surface, not just the top 2/3. Some have a nice feature of a 'Clutch brake', when you completely floor the clutch it has an additional friction face to slow the rotation of the gears, seeing as these transmissions don't have synchros and the gears are bevel cut, not helical cut. -Rougher engagement. Some also have air shift.
__________________
2000 Z28 M6 ......H/C/I, susp, exh -LOTS More!-
1995 Ford F150 Extended Cab, spray on bed liner, 5.0L V8
2006 Yamaha YFZ450 !Lid, !SA, Stainless oil filter, jetting, Cam mod , AC Nerfs, HMF Full pipe, Graphics..
Listen to the CamaroZ28.com Podcast!!
Bayer-Z28 is offline   Reply With Quote
Old 08-07-2009, 04:37 PM   #11
T/A-Bob
Premium Member
T/A-Bob's Avatar
I know this link is a re-post, but this thread reminded me of it. I really admire anyone who can shift gears like this
http://videos.streetfire.net/video/B...n-14_72637.htm
And of course his ET is pretty insane.
Old 08-07-2009, 04:46 PM   #12
97QuasarBlue3.8
97QuasarBlue3.8's Avatar
I think we need to install these in modern-day cars so people pay attention to their driving.
And talk about an anti-theft device... If you can drive it, you can have it!
__________________
2009 Colorado Crew Z71 4x4 | 2008 Volkswagen GLI | And the Ducati twins.
97QuasarBlue3.8 is offline   Reply With Quote
Old 08-07-2009, 05:17 PM   #13
96_Camaro_B4C
Some big trucks do have automatics. Allison makes them.
There are also "automated manuals" that basically have a computer working the clutch and moving the gear selector, but those still drive like a manual (just with someone who has a clue doing the driving).
Allison automatics are full torque converter automatics with clutch to clutch powershifts. They go up to 600+ hp and 1950 lb-ft in on highway applications, depending on the vocation. They blow away AMTs in performance and smoothness.
They aren't as popular (yet) in long haul, purely over-the-highway big rigs like that Lonestar, as they don't do much shifting (and manuals offer a slight fuel econ advantage when you spend the whole time cruising in a steady gear).
__________________
Joe
'96 Camaro B4C M6, White, 107k (no police use ever!), K&N FIPK, TB Bypass, Flowmaster, CAGS Elim., ZR1 SS wheels
'05 Colorado LS M5, Silver Birch Metallic, 30k, Z71, 2WD
'04 Yamaha FJR1300, Silver, 11k, 145 hp, heated grips, Yamaha/Corbin seat, silver bullet
96_Camaro_B4C is offline   Reply With Quote
Old 08-07-2009, 05:27 PM   #14
97QuasarBlue3.8
They aren't as popular (yet) in long haul, purely over-the-highway big rigs like that Lonestar, simply because they don't do much shifting.
I've driven an Allison 5-speed auto in a "little" (14-ton) truck, and it's very weird. It's a conventional hydraulic trans w/ torque converter mated to a Cat straight-six and it's awfully "jumpy." According to the techs, that's their nature. Why is that?
What kind of transmission is the type where you have to use the clutch to get going, but then it shifts itself? (Also, when stopping, you have to push the clutch in).
__________________
Old 08-07-2009, 07:14 PM   #15
Wacky Tower
5 days a week
Wacky Tower is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
