Old 07-17-2009, 12:10 PM   #1
MIGHTYMOUSE
98 WS6 in 23060 ( 8 second )
Means on contact: PM or this thread
Trades: it better be good
Price: $45k as is walk away, or 50k with a full tour and how-to including spare parts; non negotiable
Description: 98 trans am I built it over the last 3 years in a couple iterations. It has run a 9.25 on a pump gas/meth tune and an 8.73 on race gas mix @ 159mph, 17" rims and drag radials. It's daily driver reliable & I've put up to 30 hours driving on the car in one weekend including 4 passes averaging 9.2 ET in Memphis. I have paperwork for most everything. It gets about 23mpg highway cruise. This car is 2007/8 LSX King of the Street.
Details:
Mileage: 83k on body <10k on everything else
Exterior Condition: some chips and cracks from normal driving custom paint approaching 3 years old
Interior Condition: good generally stockish exept for cage and misc needed performance items
CARFAX: no accidents
Modifications: 1200+hp on full boost, has everything needed to make that happen and get down the road 'safely'; certified to 8.50, retains all power options exept a/c including air bags, 4 speed automatic o/d
Service: done by me
MIGHTYMOUSE is offline   Reply With Quote
Old 07-17-2009, 05:06 PM   #2
Jason Short
Premium Member
David, what are your plans now? Bump for a good guy and one CRAZY street car
Jason
Jason Short is offline   Reply With Quote
Old 07-17-2009, 10:10 PM   #3
96SSIndeed
96SSIndeed's Avatar
bumb
__________________
1996 Camaro SS T-56, Moser 9" with 4.11s, Custom 3" aluminum driveshaft, Pacesetter LT's, Custom y pipe, Hooker Catback, Summit 58mm TB, ported intake manifold; BMR panhard bar, Torque Arm, Control arms; Tokico rear adjustable shocks, Subframe Connectors, Underdrive crank pulley.
96SSIndeed is offline   Reply With Quote
Old 07-28-2009, 03:28 PM   #4
MIGHTYMOUSE
no new plans really, just that the car is in tip top shape and thought maybe there is someone out there who has time / money to enjoy it as i have.
Old 08-05-2009, 01:10 PM   #5
MIGHTYMOUSE
still here guys.
Old 08-18-2009, 09:00 PM   #6
Mission Man
What type of wheels are on that nice ride of yours?
I am going to have to pick a set up!
__________________
IF IT DOES NOT RUN 10'S ON THE MOTOR, IT IS ON IT'S WAY TO THE NEXT OWNERS HANDS: PLAY HARD, IF YOU DONT WIN GO BACK TO THE DRAWING BOARD AND REBUILD, BIGGER, BETTER, STRONGER; THEN GO BACK OUT THERE AND KICK SOME ASPHALT !!
Mission Man is offline   Reply With Quote
Old 08-18-2009, 10:14 PM   #7
MIGHTYMOUSE
they are bogart rr-10's
Old 08-25-2009, 01:22 PM   #8
MIGHTYMOUSE
still here
Old 08-25-2009, 03:44 PM   #9
Venomous360
Venomous360's Avatar
Good luck, there selling PRO STREET F-Bodys for $20K Not to be rude but what about it makes it a $45K car?? And yes I have heard of you and realize what the car can do. Just curious thats all.
__________________
1996 SS M6 #15
Venomous360 is offline   Reply With Quote
Old 08-25-2009, 05:20 PM   #10
MIGHTYMOUSE
they are all valuable, i guess what makes this different is that it is faster than pro-street while actually only being street
Old 08-25-2009, 05:28 PM   #11
MIGHTYMOUSE
video
http://videos.streetfire.net/video/8...-MM_201441.htm
Old 09-02-2009, 03:57 PM   #12
MIGHTYMOUSE
update w/ mods list
ENGINE: ERL364 c.i. aluminum LS2 block 6 bolt head conversion, 236/231 .601/.594 115* W2W spec from Cam Motion, Howards steel rods, Weisco custom 26cc dish forged pistons, ARP head & main studs, W2W oil pump, W2W 6 bolt ALL PRO cylinder heads, Comp 921 dual valvesprings, hollow 8mm intake valves, 5/16” inconel exhaust valves, titanium retainers, Manley locks, Smith Pushrods, Fel-Pro 6 bolt head gaskets, 99+ valve covers and truck coil brackets, Z06 Intake, ported, filled and polished stock throttle body, Hypertech 160 degree thermostat, ATI Superdamper, Moroso RACE oil pan, oversized relocated oil filter, run on Rotella synthetic
TURBO & EXHAUST SYSTEM: custom Turbo Technology turbo header system, Precision Turbo PTE-88mm medium frame turbo, Precision Turbo PT-900 liquid intercooler, custom water tank and plumbing with Rule 1500 pump, Innovative Race Gate Wastegate, Turbonetics Godzilla BOV, 3.5” downpipe to 3.5” cut out & Stainles Works 3.5” cat back.
ELECTRICAL: Turbosmart e-Boost 2 digital boost controller, Auto-Meter 100psi fuel pressure gauge, Auto-Meter Trans temperature gauge (custom glove box mount), custom triple switch panel, Optima red battery(rear), MSD LS1 truck plug wires, LS1 truck ignition coils, NGK 7173 gasketed spark plugs, Big Suff 3 engine management system with wideband, replay, and transmission control, JEGS rear safety cut off switch, Flaming River shut off handle, BMR custom battery relocation bracket, separate fuse panel for acessories
CHASSIS: BMR boxed lower control arms and low profile sub frame connectors, BMR ‘Extreme’ torque arm with front driveshaft loop, TRZ ‘roll control’ anti-sway system, V6 rear springs, HAL front drag springs, HAL 12-way adjustable race shocks, BMR tubular K-member & front lower a-arms, Earls Hyperfirm stainless steel braided brake lines, PowerSlot Pro Stop slotted and dimpled front and rear rotors, Hawk HP+ brake pads, Performance auto Fabrication Sportsman 8.50 Cage and Parachute system with Stroud pro-mod chute. Energy Suspension poly engine/transmisisonmounts and rear bump stops
FUEL SYSTEM: Twin in-tank 255LPH Walbro GSS340 fuel pumps, Russell Y-block, -8AN steel braided fuel pressure line, -6AN return line, Earls fuel fittings, Speed Inc custom fuel rails, star performance fuel filter and CAS boost referenced fuel pressure regulator, 96# Delphi fuel injectors, Snow Performance twin methanol injection system, 625 and 375ml nozzle, 220psi pump triggered by e-Boost 2, modified windshield washer tank reservior with low level light, 2nd pump triggered by BS3
DRIVETRAIN: Yank SC3400 converter, Transformance 4L80e controlled by BS3, Rossler transbrake, custom moroso tranny pan, B&M Quicksilver shifter custom fit, race tranny cooler with fan triggered by BS3, black lightweight hose and black fittings, Midwest Chassis 9” rear for ABS, 3.0 gear, full spool, 35 spline hollow axles, star flanged, billet yoke, aluminum housing, arp ½-20 wheel studs, Midwest steel driveshaft
APPEARANCE:Suncoast Creations ‘Raptor’ fiberglass hood, McEwen silver gauge overlays, 17*8 & 11 Bogart Racing RR-10 wheels, 295 MT Drag Radials 245 Contisport radials, Afterthoughts Auto license plate cover, Custom GM Carbon Metallic paint with custom flaming bird on hood, side molding removed, Smoked fog lights, custom leather shifter boot, Hurst shifter knob, BMR Polished Stainless steel LT-1 radiator shroud, custom steel window tinting from VA Solar Tinting, ghosted trans am rear hatch panel, carbon fiber rear WS-6 emblem
STATISTICS:
89k+ Miles
3825# Race Weight
Best ¼ Mile Elapsed Time: 8.73 seconds
Best ¼ Mile Trap Speed: 159.27 MPH
Best ¼ Mile 60 Foot time: 1.33 seconds
*times done on 17” wheels and tires, 23 psi boost
Old 09-13-2009, 06:08 PM   #13
horseplay
Send a message via ICQ to horseplay Send a message via Yahoo to horseplay
Wow!
__________________
93 Z28 M6 . DEAD---R.I.P.
99 Z28 A4 ---SOLD
94 TransAm M6 ---SOLD
horseplay is offline   Reply With Quote
Old 10-09-2009, 12:46 PM   #14
MIGHTYMOUSE
still here.. going to lsx shootout again with it next weekend in memphis.. come check it out
Old 10-09-2009, 01:12 PM   #15
bad95formula
bad95formula's Avatar
VERY impressive ride.
__________________
Quote:
Originally Posted by Mike Tyson
I normally don't do interviews with women unless I fornicate with them. So you shouldn't talk anymore. Unless you want to, you know
Firebird Formula - Way too many mods to list.
bad95formula is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forums Directory
