07-01-2009, 12:08 PM
rev limiter help with pcm
I just want to view what the limiter is set at in the pcm(obd1)
I have it set at 7500 on the msd but just about 100ft from the traps at about 7000 rpm I hit the limiter.Any way to view what it is set at with a free program?
I have a laptop and the cable already
__________________
1996Camaro,Solid Roller 383 ,AFR 210,Kook 1 7/8 LT headers,super vic converted to efi,digital7 ignition,12bolt rear with spool and 410 gears,th400,ati 5200 stall
10.62@128(motor) 1/8-6.68@102mph
http://videos.streetfire.net/video/S...J-1_133669.htm
07-01-2009, 04:18 PM
strange I was able to look at the fuel cutoff settings in tunercat and they are set at 9074 rpm yet I am hitting some sort of rev limit at around 7000 rpm
__________________
07-01-2009, 04:27 PM
The stock PCM tops out at 7k rpms, at least the timing and PE tables. But, I have heard some have found a way to tune around that level.
__________________
1994 Corvette: Heads/Cam/4.10
1995 Triple White TA Vert
2001 LPE TT650 Corvette Vert
2001 Ford Lightning: 425/505
2006 Cobalt LS (DD)
07-01-2009, 04:39 PM
My understanding is if you try a handful of PCMs you might find one that will let you have another 1-200rpms that is it though the pcm HARDWARE can't handle any more.
__________________
Dwayne
96 Caprice with AI 200cc package 11.567 at 115.9
07-01-2009, 05:42 PM
Quote:
thanks
I guess its time for some 28 inch tires or BS3
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
