Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join nearly 80,000 enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
- Participate in over 40 different forums and search/browse from over 4 million posts.
- Communicate privately with other enthusiasts from around the world (PM).
- Post photos, respond to polls and access other special features
- Gain access to our free marketplace to buy, sell and trade cars, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support. |
06-30-2009, 07:21 PM
Competitve Mode Mistake?
Help - What happened? I put my 2010 SS in Competitive Mode and ran the revs high. When I dropped the clutch, it stayed stuck in and the clutch (I assume) created a burning odor. I assume I over reved the engine but did I damage anything? Why did the car not burnout? First time with a true standard tranny muscle car - my 1981 Vette was an automatic. Help a dope out - what did I do wrong?
06-30-2009, 07:53 PM
i thought comp mode was made to keep the car straight for drags n not lite the tires
07-01-2009, 07:31 AM
competative mode is not for burn outs.its for launching. to do burnouts take the traction off completely. do this by pressing the traction button once. if you press it twice you turn on competative mode. you should have probably read about how to use them before doing that.
__________________
FU LBJ!!
07-01-2009, 04:22 PM
Competitive Mode
No doubt should have read the manual - the car is too fun and I had not yet taken the time. Just wonder if the smell from the over reving did any permanent harm?
07-01-2009, 04:46 PM
What RPM were you holding it at? If it was not beyond the safe operating range of the engine, you most likely only damaged the clutch. Is it still making good oil pressure?
__________________
1999 Camaro SS #3347 Lid, SSRA, LS6 Intake, Hotcam, Jet-Hot LT's, True Duals, McLeod Street Twin, 4.10's
07-02-2009, 07:03 AM
well what did the smell smell like? did it smell like clutch burning? fluid burning? oil? wood? what did it smell like? thats a good place to start. it was probably the clutch.
__________________
FU LBJ!!
07-29-2009, 07:19 PM
it work like a 2 step and it picks the determined rpm, put in competive mode@ a stop hold clutch in and you can't roll the throttle down you have to smash it, the rpm will set it self, mine went to 4600rpm and stayed their until i let the clutch go, it leaves slow @ 1st then it takes off,mite spin a few feet,almost bogs it down some. it works awesome technolgy is amazing now days.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
