LT1 garage sale!` EVERYTHING YOU CAN IMAGINE
Old Jun 28, 2009 | 06:44 PM
tagz's Avatar
I no longer have an fbody so i am getting rid of all the odds and ends i have laying around. here goes... All parts were from a 94 LT1
I put all the pictures on photobucket. too many things to organize a picture for each one, so if your looking for a picture, you will find it on this link. pretty sure i got a shot of evreything here.
http://s544.photobucket.com/albums/hh334/rathershort2/
STOCK ENGINE PARTS:
-INTAKE MANIFOLD 100
painted black, with polished fins. might need a repaint
-ENGINE ACCESSORY BRACKET 40
-STARTER 50
pretty new starter. less then 1000 miles on it
-ALTERNATOR 40
nothing special, plain old alterator. works fine
-STOCK MASS AIR FLOW (WITHOUT SCREEN) 75
-OPTI SPARK (NON VENTED) 100
never had a problem with it. ran great when i took it out
-BALANCER PULLEY 15
-STOCK THROTTLE BODY 50
-BELL HOUSING COVER SOLD
-STOCK VALVE COVERS 25
-RUBBER INTAKE ELBOW 20
-COOLANT LINES SOLD
heater core lines, upper and lower, and vent tube that goes from one head to the other. (not in picture)
-FUEL RAIL 40
polished, need to be repolished but the bulk of the work is done so its really just a clean up
-EXHAUST MANIFOLDS 25
OTHER STOCK PARTS
-PLASTIC DOOR PANEL (GOES AROUND HANDLE) 15
-YELLOW CORNER LIGHTS (STOCK) 20
-DOME LIGHT 20
dark gray
-RADIATOR COVER 10
the piece that goes from the rad support to the radiator
AFTERMARKET PARTS
-HOLLEY 58 MM THROTTLE BODY 250
ran for 5 mintues and pulled off.
-MOROSO OVER FLOW TANK 15
see picture
-ALUMINUM VALVE COVERS SOLD
polished aluminum. need to be cleaned and repolished and will look great
-MOROSO EXTERNAL TRANS COOLER 30
mounts in line so you use the stock cooler and this
-STOCK RIMS - SALAD SHOOTERS 25 EA
(two have kuhmos w/ 80% tread, one has a bald drag radial, and the other has a blown out tire on it)
-WALBRO 255 FUEL PUMP 50
was in tank with a dual pump set up, but never ran
-ARP HEAD STUDS 50
used. started the motor for 5 minutes and took it apart.
-FUEL PRESSURE GAUGE (Autometer electronic gauge) SOLD
has the electric sending unit, used when i started the car for like 5 mintues and that was it. 190 new.
-LINE LOCK - SUMMITRACING 35
from summit racing... universal line lock
-BATTERY TRAY 25
this is one of those trays with the two bolts on either side to hold the battery down
-VALVE SPRINGS - trickflow 40
these are the springs that come with the trick flow 195 heads. they were never used.
-ELECTRIC WATER PUMP 95
CSR, ran for 5-10 mintues tops. never on street.
-FUEL PRESSURE REGULATER 95
Aeromotive 13107 94-97 LT1 Fuel Pressure Regulator, used.
all parts are located in New Jersey. Most prices are negotiable.
LeftoverChinese
Jan 14, 2024 03:03 PM
Jazsun
Dec 29, 2014 12:14 PM
joe777107
Dec 1, 2014 09:32 AM
