Old 06-24-2009, 11:07 PM   #1
prophet33
supercharger question
just wondering if putting a supercharger on the auto will do anything to the active fuel management i dont think it will but i was just curious before i decide to buy one
prophet33 is offline   Reply With Quote
Old 06-25-2009, 08:01 AM   #2
JasonD
JasonD's Avatar
I am not sure yet about other brands, but the Magnacharger will work with AFM.
http://www.camaroz28.com/forums/showthread.php?t=695009
Quote:
The Magna Charger also interfaces seamlessly with the GM Active Fuel Management system (some models) that cuts the engine to four cylinders at light throttle.
JasonD is offline   Reply With Quote
Old 06-25-2009, 04:33 PM   #3
prophet33
im still looking for dyno results
Old 07-02-2009, 11:57 AM   #4
85LT1Z28MEX
Send a message via ICQ to 85LT1Z28MEX Send a message via MSN to 85LT1Z28MEX
Quote:
camaro / magnacharger
before and after programming
__________________
1:- Camaro z28 1985 LT1 13.39 sec 1/4 mile
2:- Firebird Formula 1995 LT1 M6
3.- (sold) 95 L32 Camaro stock
85LT1Z28MEX is offline   Reply With Quote
Old 07-10-2009, 03:45 AM   #5
vettered
Send a message via Yahoo to vettered
it was Street Tuning, and Dyno Tuning...
__________________
Corvette 94 Coupe A4 389 ci LT1 engine @ 11.8:1 CR
*Headman Long Tube Headers *Double 4" Magnaflows *Underdrive Pulleys *AFPR @ 50 lbs *K&N Air Filter & open lid *52mm T B *Richmond 3.54:1 Rear Axle *MSD 6A Ignition Control Unit *MSD Blaster Coil *MSD 8.5 mm *2600 rpm T C *Decked Heads *Fully Ported & Polished Heads & Intake Manifold *Comp Cams Dual Springs *Manley Titanium Retainers *Stainless Valves (2.02"/1.6")*LT4 1.6" Rollers *Callaway S/N Cam *160° Stat *PCM Custom Tuning (by me)
vettered is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
