Here is the eccentrics I was talking about
Pedders PDUSA5420 eXtreme Rear Camber and Toe Kit
Pedders has developed a set of rear camber and toe eXtreme Adjustment Bolts and Washers to get your Camaro or G8 exactly where it should be for street, drag strip, autocross of road course or road course use. The OEM adjuster provides less than a degree of adjustment. Pedders eXtreme Camber and Toe Kits provides more than 2 degrees of adjustment range. We also go one step further than the OEM and provide jam nuts to lock down the alignment bolts.
The
PDUSA5420 eXtreme Camber and Toe Kit for the G8 and Camaro is $179.00 and scheduled for delivery on Monday. You would be reasonably safe to assume that the PDUSA5420 eXtreme Camber and Toe Kit for the G8 and Camaro will be shipping to customers by Friday June 20, 2009. Our online store has real-time inventory. The moment they are in the warehouse and counted into stock the link will change from contact us currently on back-order to available status. You can place your order today and it will go into the cue for FIFO fulfilment.
https://secure.merlinsoftware.com.au...Code=PDUSA5420
Pedders PDUSA5420 carries a LIFETIME WARRANTY on the welds, bolts and washers. Install these bolts and your G8 or Camaro rear alignment bolts and washers are guaranteed to work as long as you are the owner.
The fine print and exclusions are: Stripped nuts and bolts are NOT covered under warranty. Collision damage is NOT covered by warranty.
Now as mentioned the increase in adjustability in desirable and important. Adjusting the cambers to a higher degree than OE, may require a little more effort. To assist this, I suggest you put a little anti sieze between the adjusters and the cradle brackets. This will assist you in a "slippery move to get you over -2.0 degrees, and last longer than the Camaro will.
This kit is so important, we now are including it in all ZETA systems that involve drop coils and drag racing. For the Drag Racers, this kit is a must to seriously reduce negative camber to bet more tire on the launch.
We now have over 300 kits made and ready to go. They are all hand machined, and the eccentrics are laser cut. the eccentrics are larger than OE, and again, will last longer than your Camaro will!!
If you need help in ordering, just ask us!.
thanks
mike
dms
