Old 06-19-2009, 11:31 PM   #1
omgwtfdied
omgwtfdied's Avatar
Best race setup?
Car is in my sig, im not sure what it will run. its auto.
my neighbor wants to race me in his 60 thousand dollar 2009 benz. its the v6 with 268 horse. Im not sure who will win on the 1/4.
wht should i do though? whats a good tire psi and whats the best way to run the auto in the 1/4, [D] Overdrive? or just regular drive?
thanks
__________________
1994 Z28 Camaro. Red and Beautiful. 65k
Cold Air, MagnaFlow CatBack. X Da cat yo
And my 2001 Dodge Dakota Sport. Black.
Work hard, Fly Right
omgwtfdied is offline   Reply With Quote
Old 06-20-2009, 01:05 AM   #2
rock1501
rock1501's Avatar
Try around 26-28 psi and dont do a burnout just spin them 3-4 revs to get all the dirt off the tires.Keep the car in drive and lauch at about 1000-1200 rpm.If you spin you might have to feather the throttle a bit.
You better smack the tree cause its prolly going to be a close one
GL
__________________
1996Camaro,Solid Roller 383 ,AFR 210,Kook 1 7/8 LT headers,super vic converted to efi,digital7 ignition,12bolt rear with spool and 410 gears,th400,ati 5200 stall
10.62@128(motor) 1/8-6.68@102mph
http://videos.streetfire.net/video/S...J-1_133669.htm
rock1501 is offline   Reply With Quote
Old 06-20-2009, 11:03 PM   #3
toomchz4u
Send a message via AIM to toomchz4u
What kinda Benz it is? The 4 door E class? If so I would think you would beat him but it probably will be close seeing that you don't have many mods.
__________________
95 Z28. Performabuilt 4L60E, PI 3600 vigilante, CC503, 42 lb. hr injectors, EB porting LT4 heads, 58 mm throttle body, Mac headers, Flowmaster exhaust, K&N FIPK, 3.73 gears, ACPT carbon fiber driveshaft, VFN fiberglass hood, Madtuner.com tune, UMI, BMR, KONI, and granatelli full suspension. Thanks EB porting and Mdacton.
toomchz4u is offline   Reply With Quote
Old 06-21-2009, 04:17 PM   #4
omgwtfdied
omgwtfdied's Avatar
Quote:
thanks guys, and yeah its E four door
my tiresd are pretty baled also. think it would be better if i take it like this or get new street tires?
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forums Directory
