Sonic checking heads?
Old Jun 18, 2009 | 04:51 PM
LT1 POWR's Avatar
I've got some heads I would like to have checked out to make sure they haven't been weakened by porting and will be able to handle what I want to through at them. Is there any kind of sonic check that will test them?
Since they are aluminum heads, will they expand and contract creating stress cracks? I had to have them welded in a few spots because the walls were too thin and there was a crack before I even touched them. I bought them used so I don't know if the guy ran them like that or if they were somehow damaged in the transaction. It was by one of the stud holes somewhat close to the intake valve wall.
They were originally ported by Lloyd Elliot and I further gasket matched them and did a little porting on the intake side, hopefully I didn't do too much damage.
Is there anything I can do to make sure the walls won't be too thin and crack over several heat cycles? I plan on running up to 15-20psi so I need heads that will take the abuse.
Let me know what you think. Thanks.
Old Jun 21, 2009 | 08:11 PM
Kevin Blown 95 TA's Avatar
Just from your description of them, I wouldn't use them on 15 or 20 psi of boost.
Old Jun 22, 2009 | 04:02 PM
LT1 POWR's Avatar
Well they are only "thin" in that one spot. I plan on having it welded tomorrow and adding material to the port so it's a little thicker then before. The other spots that were fixed should be thick enough since they are just as thick as they were when they left Lloyd. Most of the material that was taken out was to open up the port for port matching, so not too much was taken off the walls. I just want to know if there is anything that will check the heads for weak areas that might not hold up to the power.
Old Sep 24, 2009 | 08:32 AM
freethrowchamp's Avatar
can you post pics? 15 to 20 psi lol your going to destroy those heads! sounds like they are ready for the scrap pile as is.
Old Sep 27, 2009 | 02:54 PM
MachinistOne's Avatar
Yes they can be sonic checked - but personally I wouldn't use them because of the thin decks and the 20psi blower motor cylinder pressures, it may be hard to keep head gaskets from going unless maybe you change out to a MLS gasket.
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
danielbmx
Aug 27, 2002 11:11 PM
