Old 06-16-2009, 05:42 AM   #1
gotpball44
My Car is getting SCREWED by Techco! lol
Hey guys,
The title is not like what it sounds lol. My car is back at Techco Superchargers for the R&D. The process is underway and soon it will be available. They just finished the corvette LS3 and now going to my Camaro. They are great systems and very cool guys. Now just cant wait now till its done!
What the supercharger is all about:
The Revolutionary design allows air to move through the supercharger quickly and efficiently, without significant heat buildup, and at the highest resulting airflow volume at low boost output. The performance result is maximized horsepower and torque output.
Key Features of The TECHCO Reverse-Revolution Twin Screw Supercharger™.
* Reverse-Revolution Twin Screw Compressor with Asymmetric Multi-Lobe Screws
* 3.0L / 180 cu. in. Displacement
* Font Induction with Integrated Bypass
* 10 Inch Long Intake Runners
* Dual Stage Intercooler System with Single-Pass Coolant Flow through the A-Frame (2) Intercoolers, Large Capacity Heat Exchanger, High Volume Intercooler Pump and Recovery Tank
* Open Element Cold Air Kit with High-Flow Air Filter, CNC Venturi and High Flow Inlet Tube
* Extruded Aluminum fuel Rails with upgraded fuel injectors where applicable
* Separate 8-Rib FEAD (Front End Accessory Drive) with Dampener
* Ultra-Light Weight Aluminum Construction
* Flash Programmer
-My car had some computer problems before, but finally worked it out. (GM replaced the ECM because it was faulty.) -
-Here is a link to there site: http://www.techcointl.com/default.asp
Here is some pics of me dropping it off and doing some Baseline Dynos. (Dyno power was 380rwhp and 385 torque on a Dynojet) Pretty impressive numbers!
What the system looks like on a challenger
My Motor without the cover on
My car on the dyno
Dyno #s
gotpball44 is offline   Reply With Quote
Old 06-16-2009, 05:11 PM   #2
gotpball44
might be in wrong section, if the mod wants to move it to aftermarket engine section be my guest
Old 06-16-2009, 07:31 PM   #3
1997FormulaBird
thats really cool. are you going to beef up the rear axles to handle the power?
how much more power are you expecting to make?
good luck
__________________
1997 Firebird Formula
Home made true duals with Pacesetter LTs and
Moroso Spiral Flows, Home made CAI
1997FormulaBird is offline   Reply With Quote
Old 06-16-2009, 07:39 PM   #4
gotpball44
good luck
Im not sure if i will beef it up, depends on how much it cost.
The car should make around 520rwhp on 6psi with everything else stock.
So hopefully i dont have to upgrade the rear axles, cause i will be happy with that power for a while lol. I might switch the rear gears to 3.73 though.
Old 06-16-2009, 07:50 PM   #5
King Moose SS
King Moose SS's Avatar
that looks hella cool, but do you know what it sounds like?
__________________
2006 Trailblazer LS (ITS NOT GREY , ITS BLACK GRANITE METALLIC!!!)
Don't ask about the SKY's, they are well hidden....
King Moose SS is offline   Reply With Quote
Old 06-16-2009, 08:26 PM   #6
gotpball44
Quote:
It sounds like a kenne bell, you can go to there website and watch some vids
Old 06-16-2009, 09:30 PM   #7
JasonD
JasonD's Avatar
That is awesome, keep us posted!
JasonD is offline   Reply With Quote
Old 06-17-2009, 08:15 AM   #8
2010_5thgen
2010_5thgen's Avatar
thats a nice looking supercharger. post the numbers after you get it all done. is there any kind of warranty with this company? how much does it cost?
__________________
2010 Camaro SS/RS:Borla LT headers, Borla catback,AirAid CAI,Pedders Xa,360 Forged 22" wheels
2010_5thgen is offline   Reply With Quote
Old 06-17-2009, 03:42 PM   #9
gotpball44
Quote:
It should put around 510-525rwhp on only 6spi with everything else still stock on your car. So you can make much more power with more psi and other mods. There is a 3year/36,0000 mile warranty on the whole powertrain. Well the other kits for the other cars cost 7,5000 but the LS3 might be a little more. Its all on there website i posted.
Old 06-17-2009, 09:41 PM   #10
2010_5thgen
3 yr warranty on ALL the powertrain?! or just the motor? thats crazy if they warranty it from breaking any powertrain components. they must really trust the stock components.
__________________
Old 06-17-2009, 09:43 PM   #11
2010_5thgen
nothing on the camaro on thier web site yet but it was 8500 for the kit for the ls3 vette. is that installed prices?
__________________
Old 06-17-2009, 10:58 PM   #12
gotpball44
It is for the whole powertrain. But they will only cover it on the base map i believe. The 6psi tune only. Well that is what they are doing for me cause i am the r/d car, but i am pretty sure its for everyone else too.
Yea, they have nothing yet for the camaro. Cause they are just starting on mine. The price is for the kit with a base tune. The installation is not included. But sometime they have specials on free installations with purchase.
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
