06-13-2009, 10:19 PM
LS3 1-4 Shift ???
Is anyone else annoyed or having problems with this 1st into 4th shift crap???
I've have to do it a hand full of times because the stupid indicator comes on, but when it does come on I barely have enough forward momentum so then i put in 4th and she barely pulls through forcing the gear! On the operetion manual it specifically says if you put it in another gear other then 4th you can damage the trans.
06-14-2009, 07:11 AM
CAGS...the old headache. Just give it a bit more gas in first before you shift. It takes some getting used to the first time but after a while you get a feel for the right time to shift.
06-14-2009, 07:44 AM
Premium Member
and look in to a skip shift eliminator. They can be cheap, easy to install, and makes things much easier.
__________________
2008 Z06 - black/black, comp gray wheels, mild to wild switch
SOLD 1994 LT1 - forged 357, heads, cam, GMMG cat back and other stuff
06-15-2009, 08:05 AM
i got a skip shift eliminator from ebay for 15.00. havent put it on yet but dont pay the 30+ that the other palced are selling them for.
__________________
2010 Camaro SS/RS:Borla LT headers, Borla catback,AirAid CAI,Pedders Xa,360 Forged 22" wheels
06-16-2009, 06:23 PM
You can buy the same thing from Radioshack for $1-2. All it is is a resistor that tricks the PCM. I can't remember the correct value but if you do a search I'm sure you'll find a thread with the right info.
__________________
DOOM Master
Jet black 94 Z28 Camaro (DOOMZ28)
Running and on the road again after 3 long years!
06-17-2009, 11:54 PM
Quote:
Hear is the one from e-bay that i put on my car.
http://www.camaro5.com/forums/showthread.php?t=27170
06-18-2009, 12:37 AM
on my car. put that thing on almost from day one
__________________
LS1 TR224-112, 12 bolt
06-18-2009, 05:39 PM
Quote:
Originally Posted by 2SSRS
Yeah, that one works, but it's also $18. I looked up the resistor value for skip shift, its 2K ohms. So if you go to Radioshack, buy a pack of 2K ohm 1/2 W resistors for $1, you and 4 other people can use them to eliminate the skip shift. Just cut the signal wire, patch in the resistor, tape it up, and you are done.
__________________
DOOM Master
07-09-2009, 09:02 AM
unless an LS3 is different on this from an LT1 you should just be able to unplug the harness, plug in a resister to the one side and tape everything up...NO cutting involved.
__________________
'06 GTO black on black, m6
'35 Ford 5w coupe, LT1/T56, Heidts MII front end, '68 Camaro 10 bolt - project
'96 Z28, m6, SS hood, silver ZR1's, borla exhaust, sportlines sold 10/09
'97 SS #372 totaled 12/04
07-09-2009, 09:03 AM
Premium Member
Should be able to tune it out in the PCM, dunno if there's enough tuning support to do that cheap/free right now.
__________________
-Eric
1997 Camaro SS #2703/2892 - FQuick
Fully loaded arctic white six speed, lowered with a few bolt-ons
1999 Silverado Z71 - Charcoal Gray Metallic, LT, 3rd Door, Leather, etc.
07-12-2009, 09:16 PM
Disciple
I get that too, and it is annoying. I have found that when it comes on if I push in the clutch and wait a second or two it will allow you to go into second. When I leave the post office and head to the next stop sign it is not that far at all so to give it that much gas to go such a small distance doesn't make sense.
__________________
Now driving our Cyber Grey 2SS/RS with inferno orange interior, ground effects, sunroof, and black stripes. VIN 4005, ordered 12/17/08, produced 4/20/09, delivered 5/5/09.
www.finnsautorestoration.com
07-13-2009, 06:19 PM
I put in in 4th for just with it takes to go in and out as its the only gear it will take and then go to 3rd and its all good.
__________________
1997 Z28 (383 Stroker) - 400 RWHP
2010 RS/SS - 426 HP
2005 GSXR - 1000 CC's
2003 VTX - 1800 CC's
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
