Old 06-09-2009, 09:52 PM   #1
John_H
Confused on tire/wheel sizing
I'm totally confused on how tires and wheels are sized.
Okay, the SS has 245/45ZR-20 on front and 275/40ZR-20 on the rear and the wheels are 20" X 8" on the front and 20" x 9" on the rear.
So, I don't know how you would size the tire with the wheel. I understand the diameter, but the width difference in the wheel and tire throws me off. How do you properly size the tire and wheel?
The reason I bring this up is because in the interview with Pete from Peddlers, he said we can have a 10" front tire and a 12" rear tire. I'm assuming he meant the the tire width, but what width should the wheel be? Also, does anyone know how sidewall height affects handling. I know the larger the sidewall, the better the ride is, but what is the optimum side wall height for handling?
Thanks
John_H is offline   Reply With Quote
Old 06-10-2009, 03:24 AM   #2
MetalDragon
MetalDragon's Avatar
Send a message via Yahoo to MetalDragon
I believe he was referring to wheel width. As far as tire to wheel...I've been told that a good rule of thumb is to keep your tire width within plus or minus half an inch of your wheel width, but 275mm is about 10.8 inches on a 9 inch wheel, so who knows. If you follow this pattern...and you put a 12 inch wheel on, it would seem you could possibly put up to a 355/30/20 and have nearly identical diameter to stock. Too much or too little and the tire won't seat on the wheel properly, though and a 305/35/20 is almost exactly 12 inches wide with virtually the same diameter. Seems like there's a good bit of room to play with.
As far as optimum height for handling...technically, a strip of solid rubber wrapped around the wheel. It depends on what you want to do with it and how much of a trade off between performance and comfort. Generally speaking, less sidewall equals less "float" but rougher ride.
__________________
My 2010 Build - Ordered!
MetalDragon is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
