06-06-2009, 01:33 PM
Premium Member
The LS3 and boost...
Forgive the lack of knowledge on this one, but help educate me here.
How will the LS3 hold up to boost? I know it is a higher CR engine, probably with non-forged internals. But what all would it take to make the LS3 completly boost friendly (and by boost friendly, I mean built to withstand a good 15-20#'s of boost on a regular basis either via a blower or turbo).
This is really more for learning on my part here than anything since to my knowledge there is no supercharger kit available yet (although I am confident it is only a matter of short time), and a turbo kit is even further out on the horizon.
__________________
98 Formula WS6 M6, heads, cam, intake, bolt ons, 441 RWHP
95 Z-28 M6, 383, D1SC, FMIC, 614 RWHP on pump gas with the stock PCM,  .
06-06-2009, 06:59 PM
Magnusson's are already available, Techno is building a twin screw (supposedly around June/July delivery) Vortech is end of June delivery and I heard Edelbrock is making one as well. Lingenfelter, SLP and Hennessey already have demo SC'd Camaros, and Lingenfelter and Hennessey have plans for twin turbo Camaro's, so they are out there, just not many actually upgraded yet.
AS far as that high of boost, not really sure. Maybe an iron block LSX, with fully forged internals.
__________________
"Super Sports shall once again rule the Camaro world!"
New Ride:'07 Tahoe 3LT - Loaded!
New Toy: 1996 23' 454 Caravelle Interceptor
06-06-2009, 08:01 PM
Premium Member
I wasn't really interested in options as far as the FI model goes. I am more interested in the aftermarket LS3 or L99 and how it would handle boost, or more specifically, what needs to be done to it in order to handle a moderate to high amount of boost? Rods? Different pistons ect?
__________________
06-07-2009, 07:57 AM
I am definitively interested as well.
06-09-2009, 08:30 AM
why would you want to run 20lbs of boost every day? thats just NUTS. superchargers typically run 6-8lbs on a regular basis. turbos, obviously can run more boost but 20 is still quite alot for a turbo every day. i would say a safe 6 on a supercharger and 8-10 on a turbo.
__________________
2010 Camaro SS/RS:Borla LT headers, Borla catback,AirAid CAI,Pedders Xa,360 Forged 22" wheels
06-09-2009, 06:25 PM
He didnt say daily he said regularly, and seeing he has a 600+whp boosted lt1 id say he wants 800+ out of his ls3 if he gets one.
__________________
1996 Caprice Classic-le1 355 in the works
1972 Chevy C10 Short bed-TT 5.3 swap project
05 V-Star 1100 Classic-Cobra pipes
06-09-2009, 08:37 PM
Premium Member
Quote:
That would be correct. Just because some run low boost for their applications does not mean I want to. IMO, if you are going to set the car up to handle boost, and spend that kind of money and put forth that effort, only running light boost (under 10#'s), is a waste.
If I did this, I would want to have it be able to consistantly take the abuse that 15-20#'s of boost would put it through on a consistant basis. That doesn't mean I will rap it up to 20#'s of boost every day, but I am one to build the car so that it will handle boost. Not put boost on something it was not meant for and awaite the enevitable as some do.
The answer to my original question from my other findings seem to be; billet main caps, rods and pistons with good rings, head studs, etc. After swapping those out, the engine should take the abuse.
__________________
07-02-2009, 02:43 PM
LS3 Bossts
What I read on the LS3 is that it has the same Block thickness and very similar other characteristics as the LS9, just minus the horsepower. This block will flat out be able to take a beating and keep on going with the SS model. I'd defininely talk to a smart mechanic though if you are going to crank up 100 or more HPs on it though.
07-02-2009, 04:41 PM
Just on the mechanical end. All new crank, rods, pistons, cam (not for durability, but to maximize the package - pushrods and valve springs.), and a drop in compression ratio. From there programming and driveline upgrades.
__________________
1999 Camaro SS #3347 Lid, SSRA, LS6 Intake, Hotcam, Jet-Hot LT's, True Duals, McLeod Street Twin, 4.10's
08-08-2009, 12:03 PM
Quote:
Interesting article on improvements of the LS3 over the previous generations:
http://www.camarohomepage.com/ls3/
From what I gather, lower compression pistons with the stock crank and rods would hold 10-15 PSI just fine all else being equal. If you were to slap on ported heads and a large blower cam, 10-15 PSI would be asking for trouble IMO. Remember boost is a measure of resistance and varies with temperature.
__________________
Black '94 Z28
Forged 383 224/234 8.5:1 4psi stock heads intake& TB
Hooker LTs & cat back built 4L60E TCI2500 3.73 daily driver
08-19-2009, 10:18 AM
My Camaro is going to Lingenfelter for their 570hp (engine) TVS2300 S/C kit.
I get a 3 yr 36K mile warranty... That's why I had them do it instead of me doing it. Boost is set at 6 lbs.
You will need to change the pistons and rods (at least) to forged components to run more boost. Not sure what else you need to run 20 LBS of boost though... sounds like a LOT!
__________________
2010 RJT 6SP 2SS/RS
570HP Lingenfelter 526 RWHP 491 TRQ
Pedders Track II suspension
MTI shifter
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
