05-31-2009, 10:00 PM
Premium Member
1.796 60' with BFG DR and full suspension?
So I went to the local 1/8 mile track Friday and the best 60' time I could cut was a 1.796. This is with 315/30/18 BFG drag radials(not the best for traction) but still. I have a bolt on 96 LT1 that put down 263 hp and 268 torque through a built tranny with a 2800 stall and a 12 bolt with 4.11 gears. I've also got a full suspension that should be set up for maximum traction although I haven't checked the pinion angle since the 12 bolt went in.. The car is also lowered 1 1/4" and the LCA's are set to the top hole in the relocation brackets.
My best run was a 8.419 at 81.92 mph with a 1.796 60'. I did a decent burnout with about 15psi in the tires and most of the runs I was still spinning all the way through 1st. Race weight should be right around 3560 lbs.
So are my tires limiting me or is that about the best 60' I can get without adding power? I can tell on my last run that it hooked up pretty damn well, but I don't if I was still spinning a little or not.
__________________
1996 Z28 SS clone. A4,Black,Leather,All options,Hardtop
Pacesetter LT's,ORY,Trickflow elbow,NOS Holley 58mm TB,Moroso CAI,GMMG,DMH cutout,Dyno tune,!CATS,!AIR,!EGR,TB bypass,KBDDSFC's,Spohn Adj TA w/DS loop,SJM chromemoly adj LCA's and PHB,Strange 12 bolt with 4.11's,Pro Race 4L60E with 2800 stall.Dyno #'s 263.87hp 268.44ft/lbs.Best 1/8 mile time 8.419@81.92mph 1.796 60' on 315/30/18 BFG DR's at 3560lbs. In the works, procharged 383
06-01-2009, 06:36 AM
the LCA's should be in the lowest hole especially since its lowered, an 18" tire doesn't give you much sidewall , move your LCA's and get a 15" tire and it will do better
__________________
if its not broke, your not trying hard enuff
94 z m-6, forged 350 10.75 @ 127.92 150 shot 1.51- 60'
06-01-2009, 01:48 PM
here are some things hurting you
lowered
low on h.p.
tire/wheel combo
with that gear I bet your driving out of the power range
LCA not set up right.
heavy
Pinion angle is off from being lowered
I'm sure there is alot more too, so I would be pretty happy with the numbers you put down considering the set up of the car....... If you car is lowered etc. and on 18's its obvious you don't want an all out drag car, and thats fine. You just can't expect max performance out of it.
06-01-2009, 04:06 PM
Premium Member
Quote:
lowered
low on h.p.
tire/wheel combo
heavy
The top hole on the LCA brackets makes the LCA's parallel with the ground, which is where they are supposed to be at, correct?
Also I know 18's won't hook up well compared to 15's, but I just want to make sure there is nothing else causing traction problems.
As far as the gears, I purchased the rear end as advertised with a 3.73 gear, so the 4.11's were quite a surprise.
I wouldn't think the pinion angle would be off too much since I had it adjusted properly with he 10 bolt and the torque arm wasn't moved for the 12 bolt install.
Also I want to get everything set up for the new motor combo so I know I'll have 1 less thing to worry about later.
I just wanted to get some base runs in while I can since last Friday was my only Friday night off until around September.
__________________
06-01-2009, 05:47 PM
check your pinion angle..... the mounts and everything are going to be different....
What shocks and stuff do you have?
06-01-2009, 06:43 PM
If they're spinning at all, the tires are hurting you.  I'm impressed at the ET myself. That's like 12.80's @ 106 mph roughly in the 1/4. I'd always work with what you have first. Check the pinion and set it at 2-3 degrees negative. Drop the lca a hole or two. I think that tire should hook up with that amount of power and good suspension parts doing their job. Goodluck!
As stated above, a 3500 stall and 15" M/T Drag Radial tires on some stock rims would make things move out better and also be more consistant.
__________________
Denny Villemure
1989 Camaro IROC-Z Convertible
No Cats
www.denny.cz28.com
06-02-2009, 12:36 PM
Premium Member
Koni SA's and Strano 1 1/4" lowering springs.
__________________
06-02-2009, 12:38 PM
Premium Member
I got a good deal on a 2800 triple disc stall which should stall at around 3200 with my new motor, so I picked it up. My buddy is installing a 3600 stall. Hopefully I can take it down the track a few times to see if I like it or not.
__________________
06-02-2009, 03:13 PM
Quote:
you will
It will wake your car up large.
2800 is too small for your combo you need 3200-3600
__________________
1996Camaro,Solid Roller 383 ,AFR 210,Kook 1 7/8 LT headers,super vic converted to efi,digital7 ignition,12bolt rear with spool and 410 gears,th400,ati 5200 stall
10.62@128(motor) 1/8-6.68@102mph
http://videos.streetfire.net/video/S...J-1_133669.htm
06-05-2009, 12:58 AM
Premium Member
Were supposed to be racing tomorrow. If I hook up, I'm pretty sure I'll take him since hes still got 2.73's. I thought a 3600 would be too high with a bolt on LT1, but everyone says it'll be just about right. I figure with the LT1's stout low end torque the 2800 would have the advantage.
__________________
06-05-2009, 05:16 PM
And why is your 2800 going to stall at 3200 in your car?
__________________
Black 94Z, full bolt ons, Yank SS3600, Wolfe CM 6-point, Bogart wheels, M/T dr's, skinnies. 3.73's, LE heads, 222/226 Joe O. cam, 11.88 @ 114 mph NA, 10.75 @ 125 mph on the bottle. 140 shot.
06-05-2009, 08:28 PM
Premium Member
I think he is talking about another car
__________________
94z, a4 t-tops,3.73, k&n, tbbp,58mm NOS tb,trick flo elbo, LTs, X pipe,true duals, 160*, 97 engine, obd1, optma in back, random adj t arm, lca+ r brackets, p bar, sfc,airbags in rear, best 60'1.576, msd coil, mallory 685,pcmforless, 3600#w/d egr!air pump!sway bar!ac!bumper support! CPT ProRace 4L60E YankSS4000
06-06-2009, 07:39 PM
Premium Member
Quote:
I'm saying with my new motor combination going in this winter it should have a higher stall because of the increased hp. That's why I didn't get to carried away with the stall speed.
I also raced the guy with the 3600 stall and I spun through 1st and half of 2nd and still beat him by at least a couple cars. I know he'll pick to some in the tune, probably 15-20hp, but I think his 2.73's are really holding him back.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
