Limited Slip additive in M6???
Old Jan 12, 2003 | 07:54 PM
chiselmonkey's Avatar
I think i remember hearing someone say that by putting GM limited slip additive in the M6 it will smooth things out. Is this correct and has anyone done this or not...and does it even make a differance.
Thanks
Jr
Old Jan 12, 2003 | 11:17 PM
psychocabbage's Avatar
ugh! havent heard of it but dont see how an additive for a rear end will help a tranny?!?!?
anyways, I just did all of my fluids and didnt need any limited slip additive for the rear.. using Amsoil all around..
Old Jan 13, 2003 | 02:26 AM
stik6shift98's Avatar
im curious in that too.....anything that wil help???
Old Jan 13, 2003 | 08:21 AM
I got some limited slip additive from autozone and on the back it says it can be used in manual transmissions. I am just not sure what it would exactly do in a manual transmission and was just curious if anyone knew.
Old Jan 13, 2003 | 08:44 AM
goaliedave40's Avatar
My brother used to run the service dept. at a dealership back home. He said it helps out the rear ends on trucks, so it can't really hurt. I tried it, but my *** end wasn't making any noise to begin with.
Old Jan 13, 2003 | 12:50 PM
Jerm93z28's Avatar
hmm.. might help out the synchro's on a high miler transmission, maybe. might add some friction to make them work a bit smoother. otherwise i dunno...
jeremy
Old Jan 15, 2003 | 03:13 PM
BUBBA's Avatar
I do believe it is recommended. I use it in my 97SS with the Torson Ltd.Slip. Supposed to quiet things down. Costs around $7.00 at dealer. JMHO
Old Jan 15, 2003 | 05:44 PM
Jerm93z28's Avatar
your using it in your trans or your diff? your torsen doest need it...
jeremy
Old Jan 15, 2003 | 08:41 PM
hotrodgirl's Avatar
Exclamation
It goes in the diff-changed it yesterday. I bought Red Line gear oil at Thunder and they recommended the limited slip additive.
Old Jan 15, 2003 | 10:19 PM
I was talking about using it in the tranny. I know it works in the diff cause i had a noisey rear end when i turned until i dumped this in the diff then it fixed it. i just thought i heard someone say that they used it in the tranny and was wondering what the outcome was....
Jr
Nayr
Mar 3, 2023 08:34 PM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
