2.8 headgasket
Old Apr 19, 2009 | 04:54 PM
thebufenator's Avatar
2.8 headgasket
SO I think my 2.8 needs a new headgasket.
I wish I could do an LS1 swap, but I cant right now.
If I have to remove the heads, I figured I could install a bigger cam to make it alittle bit more peppy(yeah I know it will still be slow).
I understand that at .450 lift, the retainers hit the valve stem seals on the iron v6 heads. Is there a way to squeeze alittle more out of that? Is it possibly the get shorter valve stem seals? Or would I need to get some taller valves? I dont think buying valves is worth it, but I already have to get stem seals anyways.
The main reason I ask is, the iron heads dont have that bad of flow at .500.......its just underneath that where they suck. I know the 3400/3500 heads/intake is where its at, and I would like to swap a hybrid 3.4/3500 in at some point in the future, but its not feasible now.
Any thoughts are appreciated
Old Apr 19, 2009 | 05:41 PM
mdacton's Avatar
just get it running and drive it, don't waste anymoney trying to make it faster b/c it will never be. save the money up for something in the future
Old Apr 19, 2009 | 06:09 PM
Yeah, I do have my z28 for when I want fast.
I just want this car to be alittle less ball-less.
I can get a cam and lifters from deltacams for $100, and I figure if I only get 10Hp, thats $10 per hp, way better than with my Z28. If the heads are off its a simple swap.
Old Apr 21, 2009 | 02:03 AM
crazypurgatory's Avatar
I had a chip and the K&N air filters in my 85 camaro before it got T boned and it had some pep to it I was happy with it made a difference.
I still have the chip and the air filters if you are inserted in them.
IndyZman
Oct 22, 2015 02:17 PM
blaze309
Sep 8, 2015 05:27 PM
sodak86
May 24, 2015 03:54 PM
dylan1303
May 22, 2015 12:24 PM
OutKast
N2O Tech
Jan 30, 2003 07:21 PM
