04-13-2009, 01:01 AM
4-pack cluster gauges question?
Was just pricing a LS and LT1 camaro...noticed in the options it says nothing about the 4-pack cluster gauges that are console mounted in front of the shifter...but in the LT2 and SS models its an included option...my question is has anyone seen what the car looks like without them...is there just a dummy plastic cover where the gauges should be...wonder if I can get the gauges as an add-on to the LT1?
04-13-2009, 01:09 AM
Has a tray in that location instead, doesn't come up like the gauges do. Search around, there's photos of it out there.
__________________
Jason Dove
'95 Dark Metallic Purple Z-28 on '98 Z-28 Rims
383 w/9.5:1 compression, LT4 MTI Ported Heads and Intake, CC305, 12 Bolt and an M6 Swap.
04-13-2009, 01:25 AM
Without:
With:
__________________
Quote:
Originally Posted by Fbodfather
Wanna get rid of that Mustang and buy a REAL performance car?????
04-17-2009, 08:49 PM
Quote:
Originally Posted by Rob V
Without:
With:
What use does the button located directly in front of the transmission temp gauge serve?
04-17-2009, 11:17 PM
On the left is the traction control button, on the right is the flip-up cover to your auxiliary 12 volt.
__________________
04-17-2009, 11:21 PM
Thanks!
Another question:
Is that the door lock/unlock button between the HVAC controls?
04-17-2009, 11:51 PM
I actually didn't fiddle with that button when I was playing around in the car, but if I recall, the only switches on the doors are the ones for the windows, so I'm going to assume so.
__________________
04-18-2009, 12:37 AM
Yes, and the hazzard flasher button is just above that. Trunk release and windows are on the doors.
There's a kind of quick start guide running around here somewhere, but I'm at work and our firewall isn't cooperating tonight. I'm doing good to log on.
04-28-2009, 08:04 PM
Can I add the gauge cluster on my 1SS?
04-28-2009, 10:06 PM
Don't see why not. I've seen them listed as a dealer accessory. I imagine there's a harness behind the dash somewhere.
04-28-2009, 11:12 PM
Quote:
Its the burnout button. Push it and it lets you do burnouts. The little picture says so.
04-29-2009, 06:15 AM
That's great...
04-29-2009, 09:27 PM
thanks metal.......made my day
05-03-2009, 06:04 PM
I have a question. If you get a trim that does not include the 4-pack of gauges them you just don't get to know your oil pressure and volts? I guess I can go without knowing the oil and tranny temps but whats up? Do we atleast get an idiot light for the other two?
05-03-2009, 08:57 PM
Yes you will get an idiot light for all that. Most cars today don't come with oil pressure or volts gauges anymore.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
