Old 04-10-2009, 09:42 PM   #1
Hal Fisher
Hal Fisher's Avatar
304 at the crank?
Is hp and ft lbs number given at the crank? If so what are the rear wheel numbers?
Hal
Hal Fisher is offline   Reply With Quote
Old 04-11-2009, 10:31 AM   #2
BC2002SS
Send a message via AIM to BC2002SS
someone was to get the first.
__________________
2002 SOM SS 345 HP, 1LE, GMMG chambered exhaust
1986 Fiero GT 3800SC 4T65E-HD
new best 1.939 60' 12.909 @ 104.50
BC2002SS is offline   Reply With Quote
Old 04-12-2009, 04:01 PM   #3
305fan
numbers from manufatures are always at the crank.
__________________
89 Formula 350
SDPC Vortec TPI Intake, Edlebrock E-Tec 170 heads, ZZ9 cam, 1.6 Crane Gold RR, SLP 1 3/4 headers, SLP runners, Tuner Pro R/T Software
B&M 2400rpm stall ect
2007 Cobalt 2.4 SS auto sedan
305fan is offline   Reply With Quote
Old 06-24-2009, 12:00 AM   #4
krj-1168
As for what are the numbers at the rear wheels - the only way to be positive would be to put several V6 Camaros on a Dino and see what the averge is.
But as an off hand guess - assuming a 15% power loss - the numbers should be about 264 hp & 237 ft-lbs at the rear wheels.
krj-1168 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1996-2010 CamaroZ28.Com. All rights reserved.
Forums Directory
