Hey guys I'm new to the forum but I frequent other Camaro forums.
I started this thread at Camaro5 then carried it over to 5thgen, so now I bring it to you guys.
If you can contribute by posting links to other upgrades it would be appreciated.
This is just the V6 thread I have also posted a V8 thread in the V8 forums
V6 (DI LLT)
Headers
*1Holden Commodore VZ Long Tube tuned headers:
http://www.bestmufflers.com/bshop/pr...95d4b7d61b5671
Part number: PH5069
Price:
$505.00
*1Holden Commodore VE Shorty Headers:
http://www.bestmufflers.com/bshop/pr...233709a36adb98
Part number: PH5080
Price:
$440.00
Exhaust
GMPP exhaust system:
http://www.gmperformanceparts.com/_r...09_Catalog.pdf page 164
With tips: Part number: 92206990
without tips: Part number: 92225673
Magnaflow:
http://www.magnaflow.com/02product/s...zone=all&id=40 2.5 in. system, Dual split rear exit.
part number: 16583
Magnaflow:
http://www.magnaflow.com/02product/s...zone=all&id=41 2.5 in. system, Axle-back, Dual split rear exit.
part number: 16584
Air Intake
GMPP Air intake:
part number: 92212304
Suspension:
Pedders Suspension:
http://www.peddersusa.com/products/21
Camaro Steet I
Camaro Front Radius Rod Bush, Item code: EP6577
Zeta Differential Mounts, Item code: EP1167
Zeta Rear eXtreme Sub-Frame Co, Item code: EP1169
price:
$349.99 with package, $545.95 indidvidually
https://secure.merlinsoftware.com.au...&Level2=CAMARO
Sport Package
Zeta eXtreme Adjustable Sway Bar Kit, Item code: 429006ADJKIT
price:
$699.99 with package, $891.15 individually
Camaro Street II
Zeta Front Left GSR Strut, Item code: 9464L
Zeta Front Right GSR Strut, Item code: 9464R
Zeta Front Sport Coil 634mm, X2, Item code: 2954
Zeta Rear GSR Shock, X2, Item code: 9295
Zeta Rear OE HD Rear, X2, Item code: 2957
price:
$1,299.99 with package, $1582.42 individually
Camaro Track II
Zeta Front Control Arm Inner, Item code: EP6561
Zeta Rear Control Arm Lwr Out, Item code: EP7266
Zeta Rear eXtreme Sub-Frame Co, X2, Item code: EP1169
Zeta Rear Sport Coil 643mm, X2, Item code: 2955
Zeta Rear Toe Link Inner/outer, Item code: EP7267
Zeta Rear Trailing arm Inner, Item code: EP7265
Zeta Steering Rack/Pinion Mnt, Item code: EP2112
Zeta Upper Control Arm Rearwar, Item code: EP7263
price:
$2,999.99 with package, $3,372.56 indidvidually
Eibach Springs:
http://eibach.com/cgi-bin/start.exe/eibach/index.html
Pro-Kit (performance lowering springs):
part number: 38143.140
http://eibach.com/cgi-bin/htmlos.exe/02784.2.4116424451400009395
Sportline Kit (etreme lowering springs):
part number: 4.14338
