Old 07-21-2002, 06:51 PM   #1
Zomie
Send a message via ICQ to Zomie
Post What gauge wire to use?
Well, I got 2 amps, 1 250 watt one and a 500 watt amp. Powering 3 10" subs, what guage wire do I need for amp and the wire from the amp to the subs?
__________________
95 Camaro 3.4L M5, I need a new car :-(
Own www.zomie.com and often post the videos and links from here on there.
Zomie is offline   Reply With Quote
Old 07-21-2002, 07:04 PM   #2
Klypto
Send a message via AIM to Klypto
4 guage from bat to amp....
i have 12 from amp to subs...
can use 8 from bat to amp, but i recomend 4....
- 1998 Black Camaro A4 -
3800 Series II V6
K&N Filter
AOL/AIM: Binkyboy88
This is my AIM buddy icon:
http://www.angelfire.com/nb/corycamaro
__________________
LS1 TR224-112, 12 bolt
Klypto is offline   Reply With Quote
Old 07-21-2002, 08:58 PM   #3
LS1 RULZ
4awg from the battery to a D-block. 8awg from the D-block to each amp. 8awg for each amp's ground. Both grounded to a common place.
__________________
The White Rascal SOLD
Crank up the drums, crank up the bass,
Crank up my Les Paul in your face!
LS1 RULZ is offline   Reply With Quote
Old 07-21-2002, 09:03 PM   #4
redz_02
Member
Go for 1 4 guage input into 2 8 guage output distrobution block. Something like the SXPK4DANL on
www.thezeb.com/caraudio/lightningaudioampkits.html
should do fine. It is a dual amp wiring kit, and a good one.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift knob, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
__________________
'02 BRR Z28 M6, hurst shifter, Borla, Wisperlid W/K&N, Bauer TB, g5x1, HAL QA1's, eibach prikit in back, bmr LCA-LCA reloc.-adj PHR, QTP LT's, TTII's, Panasonic dfx99, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev 6.5 K2's.
borla and lid => 330.2 rwhp 344.4 rwtq
redz_02 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
