Gmmg ?
Old Mar 27, 2009 | 03:18 PM
dr97z's Avatar
Gmmg ?
I have a thought for a true dual setup. I'm trying to figure out what kind of chambered mufflers GMMG uses on their exhaust. Instead of running a single pipe to the rear end then y-ing out over the axle, why not run two pipes back and over the axle with the same rear section setup. Does anyone know what you could use for comparable mufflers like GMMG uses?
Old Mar 27, 2009 | 03:37 PM
LT1 POWR's Avatar
They are just chambered mufflers kind of like "sweet thunder". I will be doing something like this after I get all the motor work done. Running dual 3" pipes, an x pipe and then connecting up to the gmmg. Instead of having 2 y's. I figure it will change the tone a little, but it will still have that awesome gmmg rumble. Shouldn't loose that much ground clearance either if I run it in the stock location.
Old Mar 28, 2009 | 04:05 AM
dr97z's Avatar
Yeah, I know that, but who makes one that resembles them. I don't want to have to buy GMMG exhaust then have to redo 1/2 of it to get what I want. I am glad I'm not the only one with this idea. I'm suprised GMMG hasn't done it themselves.
Old Mar 28, 2009 | 08:46 AM
green.Z's Avatar
Do a Google search for "Sweet Thunder" for aluminized chambered mufflers and "Stainless Works" for stainless chambered mufflers.
Old Mar 28, 2009 | 03:47 PM
collier341's Avatar
check out http://www.classicchambered.com. it's the same type of exhaust gmmg uses and they sound awesome!
Old Mar 28, 2009 | 04:30 PM
dr97z's Avatar
First of all, thanks for the replies. After looking around, though....does anyone have pics of their over the axle setup with borla XR1's. I thought maybe the same setup with Borla XR1's would be cool too, but I definately want to run out the back. They seem pretty compact to run them the same way. Any pics?
Old Mar 29, 2009 | 08:54 AM
joeSS97's Avatar
Search for Z28Roxy...she has that set-up.She had some pics and vids on her site. You could PM her,shes a nice lady.
Nickster 7
Aug 27, 2015 10:12 PM
BLK1997Z28
May 7, 2015 03:01 PM
Cobraeater
West South Central
Apr 6, 2003 02:51 PM
Mystery Z28
Oct 20, 2002 11:35 AM
sleeperZ96BT
Sep 4, 2002 08:26 PM
