All-Ignition Dragonfire Distributor(Opti-Spark)
Old Mar 15, 2009 | 05:33 PM
Airbornec507's Avatar
Post All-Ignition Dragonfire Distributor(Opti-Spark)
DF Race Series Specifications
CNC machined billet 6061-T6 aluminum housing
Double O-Ring Seal to help maintain proper protection against distributor contamination
Dual Venting through the housing and cap
High Performance Brass Terminal Cap
High Performance Riveted Rotor
Highly accurate, optical pickup
Accurate through 8,000 RPM
Adjustable Timing Advance
Anyone have any experience with this Opti-Spark or have any facts whether first hand or second hand based on someone who has used this opti? They are $300 and are comparable to the dynaspark opti.
Thanks.
Old Mar 15, 2009 | 06:41 PM
camarobird92's Avatar
Search "All-Ignition" on here. Might not be about that particular Opti, but their factory replacement one sucks.
Old Mar 15, 2009 | 07:45 PM
^Yeah I've done that but haven't come up with this particular one yet. If the companies stock replacement "sucks" that doesn't bode well for their bread and butter piece. How did you come upon the opinion that it "suck". I'm interested. Trying to get a piece equivalent to the Dynaspark without droping $500.
Thanks.
Old Mar 15, 2009 | 08:29 PM
Just countless threads from people that bought the unit from them on E-bay. They were selling their knock-off unit as an AC Delco piece. It would last a few months normally and they didn't seem to stand behind their product well.
Old Mar 16, 2009 | 01:08 AM
I do remember folks talking about the ebay item. If that's the same product yeah I'd definately stear clear of that.
Anyone have any input on the Dragonfire Unit?
Old Mar 16, 2009 | 07:25 AM
shoebox's Avatar
As far as I am concerned, I would not buy anything from them after their previous opti dealings. They made their bed, now they can lie in it.
If it is a generic version of the Dynaspark, they will probably be available from other sources.
Old Mar 16, 2009 | 01:16 PM
^Good point. I doubt I'd want to deal with that company anyway due to the problems I've heard about them on that ebay unit.
Old Mar 16, 2009 | 01:23 PM
mzgp5x's Avatar
I purchased a Dynaspark Opti. It did not fit a 97 LT1 engine (timing cover interfearance). I machined the "cnc" housing to fit. It was also coroded inside. The rotor was a stock piece with one (1) single rivet to hold the brass contact. Also, the internal cover seal that separates the high voltage section from the opti section was a loose fit. The gm parts opti is a good unit. Always fits. I think gm opti is better than the Dynaspark. All you need to do is use two (2) rivets to fix the brass contact. I have also used the Summit Opti. It is on par with the gm opti, but, also must be modded with the rotor contact rivet. I wasted my money on Dynaspark. I am guilty of a bad purchase, and, I could have had two gm parts opti for a single Dynaspark (kicking myself). All of thiis is, of course, my experience and opinion. I am intimate with the gm opti. HTH.
(97ss 383-D1 M6) B.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
autoxr166
Sep 25, 2015 04:21 PM
1995Blackz28
Jul 20, 2015 09:34 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
