cam for a turbo?
Old Feb 24, 2009 | 08:21 AM
1996camaroSSclone's Avatar
cam for a turbo?
Where did all of you get your cam for your turbo setup and for how much? Custom or shelf grind?
Old Feb 24, 2009 | 09:45 AM
jsetzer's Avatar
I say cam it like you want it to drive - There are "ideal" cams, but the turbo will make power either way.
Look up Speed Inc's car when they had the lt1. He did a lot of cam swapping and found that every time he went to a bigger cam (even ones with more overlap that suggested for boost) he made more power - Just at a higher rpm range. Well guess what an NA car does with a bigger cam.
If you want to spin it to 7k, get a cam that will do that. I have a 218/224 112lsa cam - technically I still have a little bit of negative overlap, but between the baby cam and tiny turbo I only spin it to 5500-5700ish at most.
Old Feb 24, 2009 | 01:43 PM
I'm looking to spin it to around 6500. I don't really care to see 7k.
Old Feb 24, 2009 | 02:03 PM
jay_rich's Avatar
mine was custom spec'd by comp cams
230/236 .544/.555 on a 114LSA (all on 1.6RR)
comp grind#lt1 3315/3316 HR114.0
Took them 3 business days top my door in canada!
Jay
Old Feb 24, 2009 | 02:09 PM
Jay
How much was it?
Old Feb 24, 2009 | 03:35 PM
jay_rich's Avatar
Originally Posted by 1996camaroSSclone
How much was it?
I think it was 302us shipped to my house. I dont think they charge shipping. Also tell them u need the long dowel for the vented opti. They put the wrong one in mine.
Jay
Old Feb 24, 2009 | 05:56 PM
boosted-lt1's Avatar
Jay,
How do you like that cam?
Thanks,
Scott.
Old Feb 25, 2009 | 10:03 AM
RealQuick's Avatar
I had that same cam in my N/A setup stock bottom end... 383rwhp @ 6000rpm / 353rwtq @ 5300rpm. I liked it.
Old Feb 25, 2009 | 05:00 PM
jay_rich's Avatar
the cam hasnt been run yet. I am still in the process of building my hot side.
Jay
Old Feb 25, 2009 | 07:29 PM
1982z28with18s's Avatar
Holy crap, I forgot about that setup, but I remember now you posting about it a lot back in the day.
Old Feb 25, 2009 | 08:45 PM
reamo04's Avatar
holy facking torque, i bet that was fun to drive
Old Feb 25, 2009 | 09:43 PM
jay_rich's Avatar
My N/A setup did 411RWHP@6080rpm and 396RWT@4500ish RPM....it was fun to drive. Mash the gas at 80kmph and feel the backend kick out. Merging on highways was fun
Jay
Old Feb 27, 2009 | 01:21 PM
RealQuick's Avatar
Yeah, it seems like it was so long ago! That was back in 2003... and a few months later I tore it down for the big build. Never got a chance to get it back together.
The tq was great... those numbers were with LE stage 2 heads from 2003.
Old Feb 27, 2009 | 03:46 PM
Cool. I'd like to see how it works with a turbo.
What did you guys think of the street manners/drivability/sound?
Thanks,
Old Feb 27, 2009 | 03:51 PM
RealQuick's Avatar
Thanks,
It had a good lope to it (probably a 5 on a scale of 1-10). Powerband was perfect IMO. It would buck below 1500rpm until I got the tune worked out, then it pulled pretty smooth down low.
