2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Suspension] Pedders Suspension Benchmark Track Testing and New Jersey Track Day
Old Feb 21, 2009 | 12:50 AM
DMS Motorsports's Avatar
Dan VanHorn, FlyByU has done a terrific job of putting this event together. Eric Hruza from Arrington has as worked very on on this as well. The end result is an outstanding Event. This is not an ordinary track day. This is an EVENT. Pedders and Arrington are proud to support Dan as sponsors for this event. We are so excited about this event that we are bringing a couple of guests stars and cars.
Eric Hurza of Arrington will have his Arrington Powered 440 c.i. HEMI Pedderised 300C at the track.
I will be there with my Pedderised, ProCharged G8.
We are looking for a box stock 5.7L LX and / or box stock SRT8 as well as a box stock G8 GT and / or box stock G8 GXP. We want to do baseline skid pad tests on these vehicles as well as benchmark them on the track with 1 warm-up lap and 2 hot laps per vehicle. While Eric and I both consider ourselves to be hot-shoe drivers (NOT!) we have recruited a couple of professionals for this testing. You may already know that Buddy and Joey Arrington have a four decade long relationship with NASCAR. I cannot name the drivers names at this time, but you can safely conclude Dan's track day will have a couple of NASCAR drivers on hand.
If you can provide one of the stock vehicles I'll bet there is a photo opportunity at hand and maybe even a lap or two with a NASCAR Driver in the left seat and you in the passenger seat.
Rick Bottom, a custom builder that has been doing SEMA vehicles for many years will is planning to bring his Pedderised GSR equipped ProChaarged
for benchmarking too. Using professional drivers on the same skidpad and track surface will provide quality comparative numbers. We have some logistical challenges to address along with details regarding the drivers, NASCAR, team sponsors and driver sponsors. At this point I would say we are 80% there. We'll post final details as soon as we can.
Rick and I are just hoping not to be embarrassed by Arrington and their Good'ol Boys Gang from NASCAR. I wonder if they have a fix in for the results? We'll know if they run better times, because if they win it must be fixed. After All, they are all Good'Ol Boys and we are strangers with a car built in the land of OZ. Excuse me, for a moment I forgot it is bench marking and not racing!
Arrington and Pedders are really looking forward to this event with the LX community and a few Interlopers from brand X. Well Done Dan!
This event is open to all our Pedderised GTO and G8 owners. I am sure some of our other Dealers will attend as well. Dan for the LX community. Dan approached Eric and Eric approached me. They are doing all the heavy lifting. All I have to do is show up and not be embarrassed by the hot cars with good drivers.
To register for this event contact Dan via this email njtrackday@taggamers.com
Once again, we want to extend our thanks to Dan for doing an eXtremely professional job. Eric, What can I say -- Awesome Job!
Old Feb 21, 2009 | 12:51 AM
Info on Arrington Engines
Eric at Arrington, is a great guy. I spend a week at Arrington Engines. What Pete says about their relationship with Pedders is being very modest. Buddy Arrington, was a great Nascar driver for Chrysler in the late 60s early 70s. Now they make all the Nascar motors for all Dodge/Chrysler teams for Nascar and also for Toyota for the Truck Series. What was suppose to be 30 minute tour of their manufacturing and R&D facility, turned into a 3 hour tour! It was off the charts.
Erc's LX is fast!! As well as he has a complete TrackII Pedders suspension. It was set up for more drag race settings than road race settings when I was there. But this should be fun!!
I think Pete's G8 has advantage due to weight, tires and suspension setup. But watching these 2 rocket ships go back to back, will be a trip and worthy of watching
mike
dms
Here is some pictures of Arrington Engines.
Old Feb 21, 2009 | 05:53 AM
Rob@WretchedMS's Avatar
I will be there.
This is going to be a good time!
Old Feb 21, 2009 | 07:45 AM
JasonD's Avatar
Admin Emeritus
Freakin' awesome! The pics are incredible!
Old Feb 26, 2009 | 03:07 PM
Justice Pete's Avatar
Your Camaro is welcome and the track is http://www.njmotorsportspark.com/
GTO Car Preparation for Track Use
1. Flush / Replace Brake Fluid
2. Flush / Replace Power Steering Fluid
3. Change Engine Oil
4. Flush / Replace Coolant
5. Rotors and Pads should be reasonably fresh with no more than 10K of use.
6. Upgrade radius Rod Bushes to Pedders EP9166. The OE fluid damped radius rod bush is NOT designed for track use.
7. Check every nut and bolt in the suspension and driveline to make certain they are tight. This would include the drive-shaft and half-shafts.
8. If you are not an expert technician, take you GTO or G8 to an expert technician before hitting the track. Your safety and the safety of others may depend on this.
G8 Car Preparation for Track Use
These are newer vehicles an I am ASSUMING you are under 10K on the clock.
1. Replace the OE brake pads with a more suitable track pad. The OE pads do NOT like the heat of track use. The OE pad tracked will crack and chunk. I will be using a new compound pad at the direct recommendation of GM engineers from Cobalt Friction with new factory rotors front and rear.
2. Change engine oil
3. The side loading fluid damped radius rod bushes on the G8 are not as bad as the GTO bushes. They are NOT designed for track use and we recommend replacing them with Pedders EP6560
4. Check every nut and bolt in the suspension and driveline including drive-shaft and half-shafts before tracking your G8.
5. If your G8 has more than 10K on the clock follow the same fluid, rotor and pad schedule listed for the GTO.
6. If you are not an expert technician, take you GTO or G8 to an expert technician before hitting the track. Your safety and the safety of others may depend on this.
First Time Track on the track Advice
This is not a race. There are no awards for finishing first or best spin. Go slow and get comfortable with the track and your car on the track. Knowing the track is essential. Knowing the track can save your butt. I like to run at Gingerman, because I know the track. There is a GM executive with so many laps at Mid Ohio he is almost untouchable there. He is a very good driver, but he is a better driver at Mid Ohio because he knows the track so well. Your performance will improve as the day progresses because you will learn the track better with each lap.
No one will point and laugh if you are cautious. If they do they are absolute idiots and have no place at an event like this. Talk to the people who do this frequently. They will be more than willing to provide insight on how to safely navigate the course. If the speeds make you uncomfortable, slow down. You know your limitations better than anyone. Track days like this are a great opportunity to become a better driver. They make you safer on public road ways at legal speeds. EVERYONE should autocross and road course because you learn so much. The best most experienced drivers leave every track day as better drivers. So do the most inexperienced. Come on out and enjoy a great day with your car of choice, but don't get too excited or have too much fun. Restraint is the order of the day.
If you have a fire jacket or single layer suit for drag racing, wearing won't hurt anything.
Completely empty your vehicle. Leave nothing in it any where.
Remove your driver's side floor mat.
If you have a forced induction system do not get on the track with less than a 1/4 tank of fuel. A hard turn can cause fuel starvation and a lean burn. Lean burns are bad.
Slower will frequently be faster. Over driving your skills, tires or brakes will slow you down. Backing off and smoothing things out will almost always result in better laps. Your tires and brakes will appreciate your restraint.
I cannot take credit for this last piece of advice. A far more experienced racer gave it to me. Over the years I have found his statement to be absolutely spot on. Bring or buy the best brain bucket you can afford. I do not know a single person that has actually needed / used their helmet in an off-track or worse situation that thought they had spent too much money on a helmet.
Spectators are welcome as are people that are thinking about driving at a road course event but would like to observe for a day before they sign up for the next event.
Old Feb 28, 2009 | 10:17 AM
JasonD's Avatar
Admin Emeritus
Some good info there, for any track day!
Old Mar 8, 2009 | 03:42 PM
Anyone going to come check things out?
Old Mar 8, 2009 | 03:53 PM
JasonD's Avatar
Admin Emeritus
Do I ever wish I could!!
Old Mar 8, 2009 | 03:55 PM
it's only a short drive from Detroit....lol
Old Mar 10, 2009 | 05:55 PM
What started out as a track day is now officially an event you don't want to miss. We are really looking forward to seeing Stacey Compton at the Pedders Benchmarking Session in New Jersey.
A Little About Stacy
Stacy was born and raised in the small community of Grit, Virginia. With all his travels while employed by NASCAR teams as well as the time spent away from home while working in the Charlotte, NC area, he never considered leaving the area where he grew up.
Stacy with daughter Olivia Stacy comes from a hardworking tradition of self-reliance and from a family that has worked in the automotive, real-estate and cattle businesses for many years in south-central Virginia. Staying true to his heritage Stacy continues to raise pure-breed Black Angus Cattle as a hobby just a few miles from the farm on which he grew up.
He graduated from Lynchburg Christian Academy (now Liberty Christian Academy) in 1985. Stacy later married Vickie Younger, a local girl that he has known all of his life. The couple now has two daughters, Olivia Grace, born December 7, 2004 and Isabella Reese, born June 3rd, 2007. Before Vickie became a full-time mother and wife she worked as a Registered Respiratory Therapist.
On his farm, Stacy raises quail and pheasants for release to help to replenish the local populations which have been all but eradicated through over hunting, fewer grain crops and loss of farm land. They also plant feeder crops for the deer, turkey and other wild life. Along with 150+ head of cattle, the Compton farm is home to 2 dogs, 2cats, a llama, a miniature donkey, 3 horses and the many ducks and geese that have taken up residence on the fish ponds.
Most evenings you will find the family riding around on a "gator" (that's an ATV folks...) watching the wildlife and teaching Olivia to appreciate and to respect the land that they call home. Sometimes you might even catch Stacy and Olivia fishing in one of the ponds or picking vegetables or berries in the garden they plant and tend as a family.
Stacy's Racing Career
Racing has been a lifelong passion for Stacy who first felt the need for speed as an 11 year old racing in the KART series. In 1987 at the age of 20 Stacy's NASCAR career began with his first appearance in the Winston Racing Series (Late Model Stock). Over the years Stacy has competed extensively in the Winston Cup Series (NEXTEL Cup), the Busch Series, and the Craftsman Truck Series - where he continues to race today.
Stacey is in car #59.
Broadcasting
Stacy on the set at ESPN Just this January Stacy signed a 3-year deal to work as "lead analyst" for ESPN. "It's a huge opportunity. Any time you can get in front of 275 million homes is pretty big. I wanted to get into the broadcasting end of it at some point. I didn't know I was going to be able to get into it this quick, but I'm pretty excited about it. It's an opportunity of a lifetime for me." He is a regular contributor to the ultra-popular sports news show SportsCenter, and shares his racing expertise on three racing-exclusive programs a week during the season. He and host Erik Kuselias do a Monday "NASCAR Now" program, and Compton appears on two Sunday "RaceDay" shows.
Spectators and Drivers are welcome at the Pedders Benchmarking and New Jersey Track Day session. You can register with Dan VanHorn.
Monday, March 30, 2009
http://www.njmotorsportspark.com/tracks.html
Original Threads:
http://www.ls1gto.com/forums/showthr...hlight=vanhorn
http://lxforums.com/board/showthread.php?t=140614
Old Mar 17, 2009 | 12:59 PM
Track Day DVD and TommyZ does Pedders G8
Pedders USA, LLC will provide a DVD to every Driver that is registered and paid. I have not discussed the detail of this with Dan, but we will need the snail mail address for everyone and would also like to get a digital still of each drive by their car with their name. We have to work out the logistics with Dan.
Pedders will bring a case of DV tape to the event. Anyone with a DV camera is welcome to grab a tape and shoot video during the day. Drop the tapes off with Pedders at the end of the day and we will use the extra camera work to create the best possible DVD. With around the track cameras, in car cameras and on car cameras we should have a great deal of interesting and diverse video.
The Pedders G8 paint work and body modifications are almost complete. The G8 will be looking really good for the event.
TommyZ has done a stellar job with the car. We should have the front spoiler ready for the 30th which will be the finishing touch. Check out the detail work. Cleaning up the headlight lenses doesn't seem like a big deal, but the result dramatic. Painting the OE kidney chrome body color is another detail that becomes a big deal. Eliminating the OE black plastic on the lower grilles makes a huge difference. The body color spoiler should put it over the top.
Don't forget your DV video camarea!
Old Mar 21, 2009 | 09:24 AM
ok, Just over a week to go,
We are going to be meeting with a few cars at Burger King at Exit 45 on Rt91 in East Windsor CT next Sunday at Noon.
This is the proposed route
I would like to possibly have a couple stops to pick people up long the way.
Who's in?
Old Mar 23, 2009 | 01:35 AM
I am!
Old Mar 28, 2009 | 07:33 AM
Everyone that bought a GoPro camera, i was supplying batteries for the event. The batteries that i had bought were alkaline batteries. Well they do not recommend tham, and they are right. Everyone needs to go out and buy AAA Lithium Batteries. I will not be able to supply these for free.
Old Mar 28, 2009 | 07:10 PM
b20's Avatar
b20
let me tell you i stumble across the two g8's friday
hot hot hot!!!!!!
pete let me really look over his car what a great guy and will explain any detail of it
i mean any detail from install to track set up
good luck
david
