tons of 93-02 camaro firebird and trans am parts FS in TX
Here is a list of everything I can think of if there is anything else you need for a 93-02 f-body feel free to shoot me a pm
I’m located in Mansfield tx 76063
All prices are obo and without shipping
LT1 T-56 conversion (includes tranny, bellhousing, shifter, hydrolics, clutch basket, pedals, and bracketry with bolts)-$1200
Lt1 dual fan assembly with pig tails -$80
Ls1 dual fan assembly with pig tails-$80
93-95 V6 single fan assembly -$40
Lt1 auto radiator -$70
V6 radiator-$30
Lt1 manual radiator-$60
Lt1 ac condenser-$20
Ls1 ac condenser-$20
Lt1 headlight control module-$20
Shock sensor-$10
Driver’s camaro electric mirror in black-$25
Lt1 brake master cylinder-$20
Lt1 clutch fluid reservoir-$10
Lt1 fuse/relay cover (under hood)-$10
Electric Mirror bolt covers-$5 each
Tan or grey seat belt guides-$5each
Dual horn assembly-$20
Electric antenna assembly-$40
95 m6 lt1 PCM-$50
93-97 passenger airbag-$25
98-02 passenger airbag-$30
95-02 Firebird/Trans Am Drivers air bag in gray-$40
93-96 camaro drivers airbag-$40
93-94 firebird drivers airbag-$40
Stock PHB-$10
Stock torque arm-$20
Tinted t-tops-$80 each
Dot-matrix t-tops-$60 each
342 3-channel LT1 rear end with brakes-$280
342 4-channel LT1 rear end with brakes-$300
323 3- channel Lt1 rear end with brakes-$250
Lt1 fuel sending unit with pump-$40
Various steering columns-$60 each
Rear view mirror with pigtail-$20
6 speed rubber shift boot-$20
Firebird / Trans Am radio/HVAC bezel in gray-$10
96-02 Firebird/ Trans Am dash in gray-$100
98-02 4-channel rear axle-$40
LS1 power steering rack-$40
Ls1 steering coupler-$20
93-97 Camaro headlight bar with lights-$100
93-97 Firebird headlight support bar-$60
93-97 Lt1 radiator / fan support-$25
94-97 lt1 intake manifolds-$40
94-97 lt1 fuel rails-$25
Lt1 throttle body-$20
Lt1 factory valve covers-$20 pair
94-97 lt1 plastic fuel lines-$25 set
Lt1 brake booster-$10
93-02 washer fluid reservoir with pump-$10
T-top weather stripping (both sides)-$40
T-top A- pillars-$30 pair
T-top B- pillars-$10 pair
T-top center divider bar (on roof)-$15
T-top holders (in trunk)-$25 pair
93-02 Trans Am / Firebird dash vent set (in gray)-$25
Camaro power doors in black-$40 picked up each
Black seatbelt set (front and rear)-$40
A4 shifting linkage with all cables and pig tails-$40
Ls1 front spindle assemblies with brakes-$200
Ls1 front spindle assemblies without brakes-$80
Ls1 k-member-$60 picked up
Lt1 k-member-$40 picked up
Lt1 front spindles with brakes-$25 each
T-5 3.8 V6 tranny 91k miles-$200
93-02 coolant reservoir with good battery tray-$25
93-96 Camaro dash (not upper dash pad)-$75
3-channel Lt1 axles-$25 each
Stock LCA’s-$20 pair
Factory jack assembly with wrench, instructions & hold down nut-$25
Stock 15in spare tire-$10 each picked up
Stock 16in spare-$20 each picked up
Spare tire hold down assembly-$10
95-97 lt1 vented opti-$50
96 M6 PCM-$50
Lt1 oil pan with rails-$25
Lt1 alternator-$30
Lt1 crank hub / balancer-$20
Lt1 accessory bracket-$25
Lt1 water pump-$30
Lt1 tensioner pulley assembly-$10
Lt1 smog pump-$10
Lt1 power steering pump-$25
Lt1 coil / ICM assemblies-$20
Lt1 BBK Shorty headers and y-pipe-$200
My paypal is f-bodyparts@hotmail.com
Thanks
robbie
V6 radiator-$30
Shock sensor-$10
95 m6 lt1 PCM-$50
Stock PHB-$10
96 M6 PCM-$50
Lt1 alternator-$30
Lt1 water pump-$30
Lt1 smog pump-$10
Thanks
robbie
