volt guage in cluster reads off the charts
Old Dec 10, 2008 | 11:28 PM
93formula's Avatar
working on a buddy's car, its a 94 z28 that he picked up for 1500.00. problem is its seems to be one big can of worms, its just one problem after another, it looks like it was demodded and sold off.
we seemed to have fixed most of the issues but one that it came in with and i havent looked at was the volt meter in the cluster, reads full sweep past 18v, like its connected backwards or something. we used the volt meter on the battery it reads just under 14v so its charging normal just not reading right. any help or advice would be appreciated before i dig into it.
Old Dec 11, 2008 | 07:02 AM
shoebox's Avatar
Does it have a gauge overlay? The needle just might be off from sloppy work.
Old Dec 11, 2008 | 12:36 PM
93formula's Avatar
no overlay, when off the needle drops down to where it should be.
Old Dec 12, 2008 | 03:21 PM
93formula's Avatar
anyone?
Old Dec 12, 2008 | 03:31 PM
shoebox's Avatar
Wiring or gauge is about all it could be.
Old Dec 12, 2008 | 03:34 PM
JakeRobb's Avatar
Super Moderator
Put a digital gauge on the accessory power port and see if the numbers match up.
If the gauge reads high, but the voltage is actually fine, just make a mental note and deal with it.
If it's under 18 volts, don't worry about it. It's very common for GM alternators to charge at and above 16 volts, and the vehicle's electrical system can handle it just fine. If your alternator is actually putting out like 20 volts or something, get a new alternator (the factory alternator includes a built-in voltage regulator) and hope that it's better.
Old Dec 12, 2008 | 04:19 PM
93formula's Avatar
ill check the wiring on the alternator, but the guage seems fine because when its off it drops to normal off position. when you turn the car on it just reads off the charts like well past 18. kinda like its reversed or something. we hooked up the multimeter to the battery and its charging at just under 14 so its working fine just reading wrong.
Old Dec 12, 2008 | 05:12 PM
93formula's Avatar
checked the wiring on the alternator, from what i believe the red slim wire is the read for cluster. if it is then when i removed it the cluster reading did not change, am i missing something here?
jakerobb, where is the accesory power port?
Old Dec 12, 2008 | 08:41 PM
shoebox's Avatar
The little wire from the alt goes to the gauge cluster, but not directly to the volt gauge. Could be something wrong with the cluster, I suppose.
Your gauges fuse should show the same voltage as the volt gauge.
Old Dec 12, 2008 | 10:01 PM
JakeRobb's Avatar
Super Moderator
Also known as the cigarette lighter.
nosliw
Apr 27, 2015 04:01 PM
maybe2fast
Feb 27, 2015 08:09 AM
rwferguson43026
Feb 6, 2015 10:06 AM
sdn1997rs
Dec 30, 2014 08:30 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
