Old 11-13-2008, 11:31 AM   #1
GSS9909
Send a message via MSN to GSS9909
ls3 ss 430hp!!!
I just had and update last night on autobook and this is what changed in the power tain tab
Prepared By:
administrator
2010 Retail Chevrolet Camaro 2dr Cpe 2SS 1ET37
TECHNICAL SPECIFICATIONS
POWERTRAIN - BASIC SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
ENGINE
Engine Order Code LS3
Engine Type HO Gas V8
Displacement 6.2L/378 CID
SAE Net Horsepower @ RPM 430@ 5900
SAE Net Torque (lb ft) @ RPM 424 @ 4600
TRANSMISSION
Transmission order code MN6
Transmission Type Description 6-Speed Manual
Drive Train Rear wheel drive
MILEAGE
City EPA fuel economy estimate (MPG) - TBD -
Hwy EPA fuel economy estimate (MPG) - TBD -
City cruising range (mi) - TBD -
Hwy cruising range (mi) - TBD -
* Indicates equipment which is in addition to or replaces base model's standard equipment.
Report content is based on current data version referenced. Any performance-related calculations are offered solely as
guidelines. Actual unit performance will depend on your operating conditions.
GM AutoBook, Data Version: 144.1, Data updated 11/11/2008 11:29:00 AM
©Copyright 1986-2005 Chrome Systems Corporation. All rights reserved.
Customer File:
November 13, 2008 9:26:31 AM Page 1 Prepared By:
administrator
POWERTRAIN - ADVANCED SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
TRANSMISSION
Gear Ratio (:1)
First Gear Ratio (:1) 3.01
Second Gear Ratio (:1) 2.07
Third Gear Ratio (:1) 1.43
Fourth Gear Rato (:1) 1.00
Fifth Gear Ratio (:1) 0.84
Sixth Gear Ratio (:1) 0.57
Reverse Ratio (:1) 3.28
Clutch size (in) - TBD -
Final Drive Axle Ratio (:1) 3.45
ELECTRICAL
Battery 1
Battery cold cranking Amps @ 0 F - TBD -
Alternator
Alternator Amps 150.00
COOLING SYSTEM
Cooling system capacity - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 2 Prepared By:
administrator
PAYLOAD/TRAILERING SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
WEIGHT INFORMATION
Base curb weight (lbs) 3,860.00
TRAILERING Max Trailer Wt. Max Tongue Load
Dead Weight Hitch (lbs)
Weight Distributing Hitch (lbs)
Fifth Wheel Hitch (lbs)
Customer File:
November 13, 2008 9:26:31 AM Page 3 Prepared By:
administrator
CHASSIS SPECIFICATIONS - 2010 Retail 1ET37 2dr Cpe 2SS
SUSPENSION Front Rear
Suspension Type Multi-Link Strut 4.5-Link Independen
Suspension Type (cont.) Double Ball Joint
Shock Absorber Diameter (mm) - TBD - - TBD -
Stabilizer Bar Diameter (in) - TBD - - TBD -
BRAKES
Brake type Pwr
ABS System 4-wheel
Front Rear
Disc Yes Yes
Rotor Diam x Thickness (in) 14 x 1.26 14.4 x 1.1
Drum
Drum Diam x Width (in)
TIRES Front Rear Spare
Tire Order Code QOO QOO
Tire Size P245/45R20 P275/40R20
WHEELS Front Rear Spare
Wheel Size 20 x 8 20 x 9
Wheel Type Aluminum Aluminum
STEERING
Steering type Pwr
Ratio (:1)
Overall 16.10
Lock-to-Lock Turns 2.50
Turning Diameter
Curb-to-Curb 37.70
Wall-to-Wall - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 4 Prepared By:
administrator
FUEL TANK Main
Capacity 19.00
Customer File:
November 13, 2008 9:26:31 AM Page 5 Prepared By:
administrator
DIMENSIONS - 2010 Retail 1ET37 2dr Cpe 2SS
EXTERIOR DIMENSIONS
Wheelbase (in) 112.30
Length, Overall (in) 190.40
Width, Max w/o mirrors (in) 75.50
Height, Overall (in) 54.20
Tread Width
Tread Width, Front 63.7
Tread Width, Rear 63.7
Min Ground Clearance (in) - TBD -
CARGO AREA DIMENSIONS
Liftover Height (in) - TBD -
Trunk Volume 11.3
INTERIOR DIMENSIONS
Passenger Capacity 4
Passenger Volume (ft³) - TBD -
EPA Classification Compact
Seating Position Front Second
Head Room (in) 37.40 35.30
Leg Room (in) 42.40 29.90
Shoulder Room (in) 56.90 42.50
Hip Room (in) - TBD - - TBD -
Customer File:
November 13, 2008 9:26:31 AM Page 6"
GSS9909 is offline   Reply With Quote
Old 11-13-2008, 11:45 AM   #2
JakeRobb
Super Moderator
JakeRobb's Avatar
Cool, lots of good info in there. I wonder if it really will be 430hp...
__________________
2002 NBM Camaro Z28 M6 - best ET 13.21, best MPH 108.9, best 60' 2.14 - 325hp/343tq - Lid, Corsa, SixSpeedsInc T56, Pro 5.0 w/ short stick, 17x9 wheels
1987 Buick Grand National - best ET 13.66, best MPH 101.5, best 60' 2.08 - 253hp/334tq - 93 chip, RJC, meth, Hooker catback, 160 t-stat, shift kit, no-hop bars
JakeRobb is offline   Reply With Quote
Old 11-13-2008, 12:42 PM   #3
2001SS4Doc
http://www.gmperformanceparts.com/se...o_sitelet.html
The Dale Jr. version at SEMA has 430hp and 444 ft-lb.... I like
"L-92 type" rectangular port heads heads, int/exh: 0.551/0.522 lift, 204/211 dur, 2.165"/1.59" for a wide flat touque curve...anyone wanna take a stab at the LSA??
__________________
2001 Camaro SS Convertible A4: Bright Rally Red SLP Build #448, Modified on 02 August 2000
Future Plans: 2010 Camaro SS M6, black w/ white stripes, 2SS trim , GMPP Cat Back...right around $25,000 on Autotrader. We'll see in real life
2001SS4Doc is offline   Reply With Quote
Old 11-13-2008, 01:48 PM   #4
99SilverSS
I have no doubt that the LS3 is rated 430hp in either Vette or Camaro but what does the difference in intake and exhaust seen on the Camaro do to that power output. In any event 422hp is just fine with me. The LS3 and it's potential is the key.
__________________
2006 Dodge Charger R/T A5, Salesmans special.
4th Gen veteran - 2002 White Z28 A4, 1999 Silver SS 6M #3956, 1997 Black Z28 A4
-Ryan
99SilverSS is offline   Reply With Quote
Old 11-13-2008, 02:11 PM   #5
SSPORT10
Very interesting...wonder if that is really true and will the L99 be rated higher than 400 hp when it finally is SAE certified.
SSPORT10 is offline   Reply With Quote
Old 11-13-2008, 02:17 PM   #6
Gripenfelter
Premium Member
Gripenfelter's Avatar
Send a message via ICQ to Gripenfelter Send a message via MSN to Gripenfelter
I'm gonna guess 412 for the auto. Or 422.
__________________
'93 Z28. Engine?? Horsepower?? New powerplant coming in 2010.
'05 GTO MBM SAP M6= RWD GRAND AM!!
Pics of my 3" duals My Homepage with T-top conversion guide
Order your 2009 Camaro from Jason Debler and beat the dealer mark ups!
Gripenfelter is offline   Reply With Quote
Old 11-13-2008, 06:38 PM   #7
SSPORT10
Quote:
That sounds allright to me! Would be glad to see a hp bump when my Camaro with auto comes in Feb/March.
Old 11-13-2008, 06:44 PM   #8
ImportedRoomate
ImportedRoomate's Avatar
Send a message via AIM to ImportedRoomate Send a message via MSN to ImportedRoomate
Nice. Even though it really doesn't matter that much, that puts it up over the SRT8.
__________________
BahamaTodd
2004 GMC Canyon Z71
ImportedRoomate is offline   Reply With Quote
Old 11-14-2008, 08:42 AM   #9
JakeRobb
Super Moderator
JakeRobb's Avatar
Quote:
__________________
Old 11-26-2008, 12:57 AM   #10
Big Als Z
19 gallon tank?!?! Sheeesh! Getting like 25mpg, thats 475 miles to the tank!!
If could squeek out 30mpg, thats nearly 600 miles to a tank!!
430hp, thats cool too.
__________________
2009 Malibu LT 2.4: My NEW Ride! Yeah...no Camaro...I know I know...
1987 Camaro Z28
1972 Camaro RS: It's easy being green
Mod @ GMInsidenews.com
Big Als Z is offline   Reply With Quote
Old 11-26-2008, 10:55 AM   #11
CTK1
I'm willing to bet that the LS3 is 430 horse power. It is the same engine that is in the C6, and I doubt GM would honestly spend the extra money to detune it. They probably just rate it lower so Corvette owners don't get upset. Just my Opinion though.
CTK1 is offline   Reply With Quote
Old 11-26-2008, 11:00 AM   #12
JakeRobb
Super Moderator
JakeRobb's Avatar
Quote:
It's not about spending extra money. The intake and exhaust are different, and so it won't necessarily have the same amount of power.
Here's hoping it does.
__________________
Old 11-26-2008, 12:49 PM   #13
Big Als Z
Funny that the G8 GXP is 415, while the Camaro gets a supposed 15hp bump?
__________________
1987 Camaro Z28
Old 11-26-2008, 06:46 PM   #14
Geoff Chadwick
Geoff Chadwick's Avatar
Send a message via AIM to Geoff Chadwick
The C6, G8, and Camaro all have true dual exhaust with an X pipe, and from the pics I've seen all appear to be a similar diameter pipe with similar number and quality of bends.
Power under the 430hp mark is due to either (a) its 430hp and they just mark it less to keep vettes happy (b) due to really bad mufflers and/or cats (c) exhaust manifolds that are terrible or (d) a de-tune.
Awesome looking G8 underside shot for reference
__________________
Z284ever "Why would you say that I dislike Zeta? Does it owe me money? Did it insult my wife? Did it pee on my lawn?"
GUTTERbOY "No, the God of Abraham watches over the line and will smite any worker who attempts to bypass the toaster."
Geoff Chadwick is offline   Reply With Quote
Old 11-26-2008, 06:59 PM   #15
ImportedRoomate
They shouldn't be able to fudge the numbers. All they can do is design components like the intake and exhaust to get the numbers they want.
__________________
BahamaTodd
2004 GMC Canyon Z71
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
