Disciples (or Scott)...get in here!
Old Oct 27, 2008 | 10:04 AM
CLEAN's Avatar
For those of you that drove the V6, how would you compare the acceleration to the LT1 and LS1 4th gens, on a scale of 1 to 10 maybe.
Old Oct 27, 2008 | 05:39 PM
JasonD's Avatar
Admin Emeritus
I will say it felt like 90% of my LS1 Camaro when it was stock. Then again, it had been a while since that time, but it was terrifically impressive regardless...dare I say..."for a V6". Some of the greatest cars ever made were about the driving experience just as much as sheer power numbers. The driving experience of the V6 2010 Camaro makes up for that 10% and then some. You'll see.
Old Oct 27, 2008 | 07:44 PM
ChrisL's Avatar
2010 Camaro Moderator/Disciple
Hard to tell without doing a head to head comparison together. .
I'd say the 5th gen V6 will hold its own.. but I think an LS1 will take it. LT1s???? that could get close.
It'll be interesting to see timeslips, thats for sure.
Old Oct 27, 2008 | 07:59 PM
guionM's Avatar
Do any of you know if the V6 will be governed?
I'm guessing with 300 horsepower, it should easily touch 155 if it isn't.
If so, that makes an even stronger case for buying the V6 and just might make it the cheapest car in the US to reach that top speed if you don't have to buy packages to have a governed-free top end.
BTW, CLEAN, the LT1 typically ran to 60 in the upper 5 second range. The V6 5th gen Camaro was estimated at 6 flat, but according to a couple of people on the project, they are going to aiming for consistent sub-6 second times before they finalize the programing, if that helps put it into perspective.
Old Oct 27, 2008 | 08:06 PM
sselie's Avatar
Disciple
From: Toronto, Ontario, Canada (20 min. down the road from the "Shwa"!)
For the total driving experience, the V6 is right up there IMHO. An incredibly responsive engine/tranny combo. I drove the manual
With respect to acceleration, the V6 will not dethrone the LT1 or LS1 in a 0-60 or 1/4 mi. contest, but it will still give an excellent account of itself and it's an absolute blast to run up through the gears! Gotta love the RPM range on this baby - not to mention the sound!!
The LT1 is a beast with its low end torque, but it runs out of breath relatively early, which is exactly when the LS1 catches fire - in the upper RPM range.
On a number scale, if the LS1 is a 10, then the LT1 would be an 8 in the 1/4 mi or a 9 in 0-60 dash. The V6 5th Gen would rate a solid 7-8 in my book.
Best regardSS,
Elie
Old Oct 27, 2008 | 08:16 PM
sselie's Avatar
Disciple
I believe the V6 is indeed governed to 155 mph.
Early LT1 cars were 5.6-5.7 in a 0-60 dash with the later 285 HP versions turning a couple of ticks faster. I would be quite surprised if a stock 5th Gen V6 had difficulty breaking into the 5's on a regular basis.
FWIW, my L67 Bonneville LE stripper with a pulley and 9" open cone K&N runs a 5.9 - 6.0 0-60 on the G-Tech and has 14.5x timeslips (on cool nights) to back that up.
The 5th Gen V6 definitely felt a bit quicker than my Bonny...
Best regardSS,
Elie
Old Oct 27, 2008 | 10:52 PM
Fbodfather's Avatar
ALMIGHTY MEMBER
still working on tuning -- so too early to give 0-60 and 1/4 mile times.
All cars are electrontically governed -- based on the tire rating symbol on the car as it leaves the factory.
I don't know the governed speeds right now - but I can assure you that the LS will be governed to a much lower speed than 155 -- as I recall, the V6 (1998-2002 == because of the Eagle GA tires) was governed to 110.......
bossco's Avatar
What is the speed rating on the tires? If its fitted with a W rated tire my guess would be limited to 155 or not limited at all.
Old Oct 27, 2008 | 11:22 PM
CLEAN's Avatar
Thanks all. Mrs CLEAN still trying to decide what to get. Now if we could just get the story on white....
Old Oct 28, 2008 | 03:32 AM
Bradl1982's Avatar
Awww that's no fun. I get my VW Golf up faster then that each morning on my way to work.
Old Oct 28, 2008 | 06:45 AM
KevinK's Avatar
Disciple
...not much more I can add than the rest, ...especially since I only drove the Ivers (V8) car. But I did spend a bit of time listening to Elie (First, ...when he tore out it the blasted thing , ...and then hearing his reaction afterwards ).
Old Oct 28, 2008 | 07:21 AM
2010_5thgen's Avatar
155 for the ss? the z51 corvette is governed to 185. that sucks. whos idea was it to go with pirelli's any ways?
cant they just not govern it and make a disclamer on the car?
Old Oct 28, 2008 | 09:01 AM
ZZtop's Avatar
Reading comprehension>You
He was talking about the LS.
Old Oct 28, 2008 | 09:02 AM
CLEAN's Avatar
Where did you hear that?
Old Oct 28, 2008 | 09:31 AM
Jason Dove's Avatar
I believe 186 is the top speed it'll hit. I don't believe it's governed, that's just wind drag etc.
