Flycutting
Old Oct 17, 2008 | 01:40 PM
Chrome383Z's Avatar
Flycutting
Anybody here ever do it themselves???
I figured on Livernois Stage II LS6 heads for my new Cam (231/240 .643/.608 - 112) and I'm really wanting to either mill the heads to 59cc or run Cometics or hell even possibly do both.
Never flycutted pistons before though which I would probably have to do with any combination of the above. I "MIGHT" get away if I just use the Cometics given this particular head still used the 2.00" intake valve, but it will be damn close and I still better prepare to have to do it if the clearance doesn't check out good.
I'd prefer to do it in the car as I didn't plan on pulling the engine, but I guess if I have to I have to. Also, if anybody here had a shop do it what was the charge?
Thanks.
Old Oct 20, 2008 | 02:51 PM
Rice Killer87's Avatar
If you wanna half *** it, I believe they make pieces you can use with a drill but you still have to remove the head to get the bit into the cylinder.
If it was my engine, I wouldnt risk it and would pull it out and have it done by a shop that knows what they're doing. To really do it right, after fly cutting you really need to re-balance the rotating assembly to make sure its not off b/c of not taking the same amount off of each piston.
Welcome to making HP, its an expensive hobby !
chevyonly406
Jun 7, 2011 10:11 PM
toolmaker
Jan 23, 2011 04:39 PM
jcob
Dec 25, 2010 09:43 AM
cammed SS
West South Central
Jun 11, 2010 01:16 AM
moralesrx7
Mar 31, 2005 08:19 PM
