Recommended Octane, this confuses me...
Old Sep 11, 2008 | 11:10 AM
Need4Camaro's Avatar
Typically the recommended Octane is determined by the Compression Ratio. The higher the Compression Ratio, the higher octane you'll need to prevent pre-detonation.
If you look here...
http://www.chevrolet.com/camaro/pdf/...ifications.pdf
The V6 Camaro actually has a HIGHER Compression Ratio than the V8... Yet the V8 is recommended to use Premium while the V6 is not
V6 - 11.3:1 - Recommended - REGULAR Octane
V8 - 10.7:1 - Recommended - PREMIUM Octane...
Alittle contradicting???
Anyway - at that level of compression, would you think the V6 would benefit from using Premium + a tune?
Old Sep 11, 2008 | 12:00 PM
cause4panic's Avatar
direct injection allows for a higher compression ratio at lower octane ratings
Old Sep 11, 2008 | 04:59 PM
bombebomb's Avatar
Thats awesom iv learned something today.
Old Sep 11, 2008 | 05:59 PM
Cool, howcome they didnt do that for the LS3/L99 Model though? A 400 HP 87 Octane car would've been awsome...
Old Sep 11, 2008 | 06:34 PM
bombebomb's Avatar
My guess is cost. I think it has been discussed before.
Old Sep 11, 2008 | 08:23 PM
Grape Ape's Avatar
The V6 is from the “next generation” whereas the LS3/L99 is probably the last V8 of it’s generation. The next V8 should have DI.
The V6 is also aided by more carefully designed cooling including oil squirters that cool the pistons from below.
Detonation is cause by temperature which is the total of:
Intake air temp
heat left in the chamber from the last charge
These are multiplied (not literally) by compression. So if you can reduce one factor (chamber temp or intake air temp) you can safely increase another (compression).
Old Sep 11, 2008 | 11:10 PM
Intake air temp
With that stated, do you think we can expect a change in the Camaro's V8 motor much like we experienced with between 97 and 98 with the 4th Gens? (LT1 to LS1)
Old Sep 12, 2008 | 07:32 AM
There is no fuel in the combustion chamber to pre ignite while the compression cycle is occuring. Fuel is injected at high pressure just before ignition occurs.
Old Sep 12, 2008 | 04:57 PM
Grape Ape's Avatar
I think that when the new small block is ready GM will look around and see where the return will be highest and put them there (Cadi? trucks? Corvette?). Watch what Ford does with its new twin turbo DI V6 for hints.
If/when the Camaro gets one it will probably be pretty similar output to what it replaces with better mileage, lower displacement. Size and weight could go either way.
But I don’t work for GM and my interest in GM is all post Zeta, so I’m really just guessing so some longterm GM fans may have better guesses.
Sort of. When cruising the DI injector fires close to TDC on the compression stroke to create a small stoichiometric pocket in a much greater volume of air. This means that the computer can hold the throttle open wider at a low load to reduce pumping losses and save fuel.
When under a heavier load the DI injector fires during the intake stroke and uses the incoming air‘s turbulence to distribute the fuel evenly. And of course knock is only ever an issue under heavy loads.
Here is a pretty good wiki article: http://en.wikipedia.org/wiki/Gasoline_Direct_Injection
Old Nov 2, 2008 | 01:01 PM
damnyankee36's Avatar
There's more to cylinder pressure than just static compression ration. The effects of the cam timing can effect the overall pressures.
Old Dec 15, 2008 | 05:02 AM
SCNGENNFTHGEN's Avatar
I read it some where that the DI on the V6, has a cooling affect on the pistons, which allows the higher compression ratio with the lower octane fuel.
Old Feb 7, 2009 | 06:55 AM
Don 97 SS's Avatar
Yes, I understand that overlap plays a role too.
Old Feb 7, 2009 | 03:43 PM
Chevycobb's Avatar
subscribing for any future posts with info. learned a lot in this thread that I never knew.
Old Feb 26, 2009 | 11:45 PM
Capn Pete's Avatar
That and ignition timing too, right? Ignition wasn't mentioned, but it obviously plays a role in the timing of the cycles.
When I first read the spec sheet a few days ago, I was also intrigued at first about the fuel requirement differences, and the high/low comp. ratios of the V6/V8. But then I thought about the D.I. factor, and figured that must be the answer ..... clearly, that's the case .
Old Mar 31, 2009 | 11:16 AM
alexss's Avatar
great write up.. im learning alot today...
Nayr
Mar 3, 2023 08:34 PM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aug 24, 2015 06:41 AM
dkred94z
Aug 20, 2015 03:09 PM
