Front Sway Bar End link size?
Old Aug 15, 2008 | 09:56 PM
KCC455's Avatar
Hello,
I am looking for some advice regarding the proper length for front sway bar end links on a 02 Camaro SS. I broke both bolts on the stock front sway bar end links, so I purchased a set of Energy Suspension, polyurethane end links. Right after ordering the ones listed for an 02 Camaro, I noticed their website states to "measure the length of OEM spacer sleeve to order the correct length". I measured the stock spacer sleeve and it is approx. 2 5/16". Here is the problem, the universal on I received for the 02 Camaro has a 2 7/8" sleeve. So this one is 9/16" longer than the original one. Should I just use this new universal one or order a 2 3/8" one from energy suspension. My car has dual uses: drag strip and SCCA Solo events. I want the car to handle better and I am afraid that with the longer end links that it may reduce the effectiveness of the sway bar.
So anyone have any recommendations?
Thank you.
Old Aug 16, 2008 | 08:20 AM
NJ-LE's Avatar
Smile
KCC455:
Obviously, you could use the original spacers but I think I would ask other autocrossers (especially Camaro owners) if they've tried longer-than-stock link spacers and what the effect was. You can always cut the ES spacers back to stock length.
I assume the amount of leverage of the anti-roll bar has can be fine tuned with link length.
Please let us know what you find out.
Old Aug 16, 2008 | 04:27 PM
Bud M's Avatar
I couldn't get an exact measurement, but mine are about 2 3/4". As long as you have no clearance issues you should be fine.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
