do you need a return line and regulator with a standalone fuel system?
Old Aug 5, 2008 | 02:44 PM
Billet ss's Avatar
I'm thinking of doing a standalone fuel cell high pressure (43psi) do I need a return or a regulator,or should I do a low psi system?
Old Aug 5, 2008 | 05:12 PM
tomcowle's Avatar
I'd personally do a low pressure dilly, there is a much broader learning base to lean upon when it comes to tuning time. Either system could use a return, the low pressure stuff you can get away without using one however pressure creep may be an issue.
Some people use the pressure creep as a tuning tool when using the system off the line, the higher pressure creates a rich condition that is robbing power for a split second or so and that enables the car a chance to better hook upon initiation of the nitrous hit.
Old Aug 6, 2008 | 09:05 PM
mdacton's Avatar
I would use a holley blue without a return.....regulate it and things are simple.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
87Aerocoupe
Mar 20, 2015 01:23 AM
