EGT gauge..
Old Jul 16, 2002 | 09:25 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Post EGT gauge..
anybody use one? what cylinder did you install it in? I was assuming #1, as it gets the leanest with nitrous.
thanks.
-94 Black T-Topped Z28 M6, 10s, and daily driven!
-96 CBR F3, modded of course
-92 Talon Tsi AWD, also too many mods..
-99 Tony Kart
http://www.fastblackcar.com
Old Jul 16, 2002 | 10:16 PM
PWRMAD95's Avatar
Yeah, number one, fairly close to the exhaust port.
95 Z28
t88 buildup in progress
700rwhp or bust
Was heads+cam+nitrous.
Old Jul 17, 2002 | 07:41 AM
Jesse_Boyer's Avatar
what's an EGT guage?
Old Jul 17, 2002 | 09:53 AM
Slow95T/A's Avatar
Anyone know how much of a temp. diffrence it would be between the temp. at the primary tube and temp at the collector?
Scott
Old Jul 17, 2002 | 12:27 PM
Guido's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Slow95T/A:
Scott
</font>
Id imagine quite a bit of difference.
I know that with 3rd gens since we dont have heated o2 sensors, if we upgrade to long tube headers it is a good idea to upgrade to heated o2 sensors as well because it takes longer for the o2 sensor to heat up being down in the collector and can run rich for extended periods of time on start up.
I would think that the same concept applies here.
-Curt Ailes
86 IROC w/ T88 Turbocharger
http://www.hustonstreetracing.com
Old Jul 17, 2002 | 02:08 PM
the EG temp would be useless at the collector.. it needs to be as close to the port as possible..
Jesse-
I assume you have figured it out via context, heh.
-99 Tony Kart
[This message has been edited by JordonMusser (edited July 17, 2002).]
Old Jul 17, 2002 | 02:35 PM
JZ 97 SS 1500's Avatar
On a standard SBC , 2 1/2" from the header flange on the #3 cyl. On an LT1, since the intake distribution is a little different, either #1 or #3 would do the job.
BTW if you just look at the programming from the factory LT1 PCM, #1 runs the leanest by design.
Jose
97 SS #1500 T-76 383
88 Supra Turbo CT-26/T04
87 Buick Grand National T-70
[This message has been edited by JZ 97 SS 1500 (edited July 17, 2002).]
Old Jul 17, 2002 | 03:51 PM
Jordon, yup, I pulled my head out of my ***, much easier to understand things that way...
Anyway, hows the new setup coming?
Old Jul 17, 2002 | 05:06 PM
Sparkz28's Avatar
I have mine in the number one.....
Old Jul 17, 2002 | 06:33 PM
spark- what kind of temps you seeing.
my new setup is coming along slowly.. but surely. t-trim/forged 355 etc
-99 Tony Kart
Old Jul 18, 2002 | 08:09 AM
arnie's Avatar
<font face="Verdana, Arial" size="2">BTW if you just look at the programming from the factory LT1 PCM, #1 runs the leanest by design.</font>
Oh, how's that? Please explain your reasoning.
I'll be back
Old Jul 18, 2002 | 10:03 AM
If you look at the cylinder balances from factory the engineers took into account that the #1 cyl ran the leanest.
Jose
Old Jul 18, 2002 | 12:34 PM
sleeperz28's Avatar
Ive always hurd that LT1s blow the rear 2 cylinders first, well maybe thats just with blowers. All the LT1's with blowers around here blow 7+8 gaskets first, but I have always hurd 1 on the sbc.
Old Jul 18, 2002 | 01:44 PM
zturbo's Avatar
7&8 prob get blown easiest cause the air is being forced to the back of the intake and creates a high pressure area (all be it not huge diff but still) So that is why i would think the 7&8 lean out and blow.
why not just get all 8 egt'd and call it a day
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
Ask me about Burhead Headers If you are gonna use them
My Car
Old Jul 18, 2002 | 08:11 PM
with an NA motor, the front are leanest.. I suppose your thinking could be correct for a FI motor.
8 EGT = money
-99 Tony Kart
