Old 08-02-2008, 04:53 PM   #1
DirtyDaveW's Avatar
Send a message via Yahoo to DirtyDaveW
Single T76 LT1 Just Back from the Dyno-
Color me very happy!
Max PSI : 12
Max RWTQ: 571
Max RWHP: 574
Engine
Displacement......: 355 ci
Heads.............: Stock LT1 Castings, ported by Will Garza
Fuel Injectors....: 60# Mototrons
Compression Ratio.: 8.8:1 Diamonds
Cam...............: Custom Bret Bauer Turbo Cam
Throttle Body.....: Stock 48mm
Intake Manifold...: Stock Lt1
Exhaust...........: Log Manifold, 3" pipe all the way back to 3" Dynomax Muffler
Machine work......: Jim Pitcher-Chatham, NY 12037
Fuel System
Stock intank
NOS Inline pump
Stock lines
Stock Fuel Pressure Regulator
Tuning
PCM Tuning........: Untouched Mail Order MAF tune by Bryan Herter @ PCM4Less
Transmission
Transmission......: Stock T56 Six Speed
Rear Gear ratio
Differential......: 4.10:1 Ford 8.8 w/GM 10 bolt 'legs'
Turbo Specifics
Turbo.............: TC 76 w/MPS Wheel .96 A/R(www.forcedinductions.com)
Intercooler.......: 3" OBX air to air, front mounted
Hotside...........: "RealQuick" log manifold system
Coldside..........: Ebay 3" Aluminum pipe/coupler/Tbolt kit
Water/Meth........: NO
Boost controller..: NO
Wastegate.........: TurboSmart 38mm w/14Psi springs
Blow off valve....: Tial 50mm w/11psi spring
Dyno Facility
SGP Racing - Veterans Memorial, Houston, TX
RPM/Boost/TQ/HP Measurements(I had him start at 3K)
3,000 = 05 psi = 400 = 240
3,250 = 06 psi = 370 = 245
3,500 = 07 psi = 400 = 260
3,750 = 08 psi = 425 = 320
4,000 = 10 psi = 465 = 355
4,250 = 11 psi = 500 = 400
4,500 = 12 psi = 571 = 475 (We think the Wastegate opened after this)
4,750 = 11 psi = 571 = 525
5,000 = 11 psi = 565 = 548
5,250 = 11 psi = 560 = 560
5,500 = 11 psi = 540 = 565
5,750 = 11 psi = 525 = 570
6,000 = 11 psi = 500 = 574
6,250 = 11 psi = 475 = 565
Air fuel Ratio was 11.x:1 during 3K to 6K, then briefly went to 12.x:1
Weather conditions at the time of dyno:
1pm today 97 degrees F, 40% humidity, 29.9 barometric Pressure, dew point 69F
Test was through full exhaust, no dumps/cutouts. Air filter on. At 12 psi during the first pull, the reducer coupler at the compressor outlet popped off. Dan took a break while I got under there to put the coupler back on with a good T-Bolt. To my horror, I saw the Air filter was GONE. I remembered hitting some retread crap the other day when the car in front of me just went over it and I didn't have time to react but I didn't consider it could have wacked that low slung air filter. I don't know how long I've been driving around, drinking dirt into my new wonderful motor, but it's been at least 2 days. I bought a 3" cast aluminum elbow I found in SGP Racings Box 'o pipes and put that on there. I was frustrated when SGP didn't have a 4" K&N filter but Dan had Moshi drive me over to Pep Boys to get one, free of charge.
With that all back on and buttoned up we took the second pull. The TQ/HP lines on the graph are sooo smooth. Not jittery or having spikes and dips. This is an untouched/altered mail order turbo tune! Good Job Bryan!
I asked Dan why it was that a wastegate with 14psi springs would open up at 12psi and he said he's sees it a lot with cars that don't have boost controllers. He recommended I get a Blitz electronic boost controller so I'm going to pick that up next paycheck!
Jon (aka "RealQuick"), good job on the hotside!
__________________
'96 Z28 355 LT1, Custom Bret Bauer Turbo Cam, M6, 3.55 Ford 8.8 differential, T76 Turbo, 60# mototron Inj, Turbo Tune by Bryan Herter(PCM4Less)
http://www.taekwondoplus.org/z28/Tur...Turboinfo.html
Eighth Mile MPH: 108, full street weight/tires. Off the highway and onto the track.
DirtyDaveW is offline   Reply With Quote
Old 08-02-2008, 05:10 PM   #2
IROCThisZ28ForLife
IROCThisZ28ForLife's Avatar
Send a message via AIM to IROCThisZ28ForLife
Congrats man!!!! Cant wait to see what my T88 kit from Jon will throw out =)
__________________
Paul
Lexus SC 300:Tundra Big Brake Swap, Tanabe Drop Springs, Russel SS Brake Lines, Energy Suspension Poly Bushings, AND a little heart beating to the pulse of TWINS
IROCThisZ28ForLife is offline   Reply With Quote
Old 08-02-2008, 06:22 PM   #3
crazycat
Nice..
__________________
twin turbos wanted....
crazycat is offline   Reply With Quote
Old 08-02-2008, 09:25 PM   #4
97WS6Pilot
97WS6Pilot's Avatar
Very nice numbers. Those ported stock heads are performing well. You are very lucky to have your A/F ratio turn out to be right the first time. I used one of Bryans tunes for my base tune when I first got my supercharger. I still use it to pick and choose tables from.
__________________
97 WS6 TA, Rebuilt 355, 15psi Procharger F1A. Sold http://www.cardomain.com/ride/2373730/1
93 Turbo Corvette, Polo Green, Accel DFI Gen 7, Stock internals, Roller rockers, 218/230 Cam, Meziere EWP
97WS6Pilot is offline   Reply With Quote
Old 08-02-2008, 11:13 PM   #5
DirtyDaveW's Avatar
Thanks guys
This dyno (Dynapack) is different than any dyno I've been on before. They take your wheels off and bolt on these splined yokes. Each side of the car has a dyno box that the splined wheels go into. The great thing about this is there's no wheel slip/spin like occastionally happens on a conventional drum. The operator said it's the best kind of dyno for tuning. I know the "Mustang" dyno numbers read low compared to a dynojet numbers for a given car but I didn't know if this brand of dyno I was on today was 'optimistic' or 'pessimistic'. Tiago said it's actually quite pessimistic and he felt that my numbers on a dynojet would be over 600. It sure felt good to hear that.
Quote:
__________________
Old 08-03-2008, 10:11 AM   #6
boosted-lt1
Nice numbers. I was just wondering how the 4:10 drive with that setup?
What tires are you running on the street?
Thanks,
-Scott.
__________________
1995 Camaro Z28 M6
Heads, Cam, 76mm Turbonetics, RealQuick's hotparts.
446RWHP 440RWTQ @ 7psi (A-Trim Vortech Setup)
boosted-lt1 is offline   Reply With Quote
Old 08-03-2008, 10:36 AM   #7
DirtyDaveW's Avatar
It has turned out to be very nice for the daily driver aspect. You always hear about turbo lag but with the 4.10's it just jumps away from stoplights with a real urgency. Then on the freeway, the 6th gear takes charge and it's almost lugging the motor at 55mph.
My tires right now are the stock sized 245x50x16 Kuhmos I put on the car in 2003. They're fine for those 3rd gear and up romps but not of much use for anything below that. I'm looking at some new tires and rims but don't have a specific rim in mind other than a 17" rim, not garish and not too heavy. The tires, I just saw a listing for some 295 and 315's by M/T Street Radials that look good for the rears to me. On prior engines, I've gone thru 3 sets of Nittos and one set of BFG DR's so I know they are 'better' over all in performance but even my old setup could easily overcome those at the strip. I'll have a set of real slicks on separate rims soon for those days when I get to race at the tracks.
Thanks,
-Scott.
__________________
Old 08-03-2008, 10:20 PM   #8
slomarao
Would like to see what it puts down in 50 degree weather instead of 97. Think your going to need a in tank pump soon too. Cant believe you just have injectors and a boost a pump.
__________________
95 Silver Z28 m6--323rwhp/338rwtq bolt ons
Trial pass: 2.1 60ft 13.1@109 Had a few problems, way to many. Rod bolt went, now building a 353: LE cam, cleaned up heads, the usual.
slomarao is offline   Reply With Quote
Old 08-03-2008, 10:47 PM   #9
DirtyDaveW's Avatar
Yes! Me too! I'm so glad I'm at the point where I can enjoy the car, even though I'm still adding this and that. I'll go twin Walbro's in-tank within a month. As to the injectors and pump, I know. I've been reading the Forced Induction threads these past 3 years as I've been accumulating parts for this project and it seemed the common aspect of every success story was that the tune was imperative. Bryan Herter's name seemed to come up a lot so I tasked him with coming up with the tune. Far before I got the car running, I got the mail order tune and opened it up in my LT1 Editor. I'd been disappointed in past tunes from MTI and Ed Wright for my prior motor to see that they'd charged $275(MTI) and $350(FastChips) but had only (a) raised the rev limit (b) zero'd the knock tables (c) Turned the fans on early. In stark contrast, Bryan changed tons of stuff. The truth in the telling was actually driving the car once it was all together. Smooth running, A/F ratios stunningly right on the money whether cruising or boosting. I gave him every nuance of the setup in terms of hardware, goals and driving style and he seems to have pretty much nailed it. I'm sure there's probably more to be had by tweaking it, but for a baseline, I can't imagine how it could have been improved.
__________________
Old 08-04-2008, 06:19 AM   #10
number1
Those are nice numbers. I'm sure your car is a blast to drive.
Bryan is the man, he has done great things with my N/A and S/C tune, so he will be tuning my car whenever something has to be tweaked.
__________________
1996 Z28
number1 is offline   Reply With Quote
Old 08-04-2008, 08:33 AM   #11
RealQuick
Supporting Vendor
Nice Dave!!!!!! Just think, with a little more boost and a nice set of AI or LE TFS heads, you should be able to hit 650-700rwhp on a dynojet. I think the dynapack reads lower than a dynojet because it loads the car like a mustang dyno.
__________________
96 TA WS6... 383ci + T76 =
95Z M6 - heads/cam... 383rwhp/353rwtq sold
www.lt1boost.net ... your home for turbo hotparts
RealQuick is offline   Reply With Quote
Old 08-04-2008, 08:35 AM   #12
RealQuick
Supporting Vendor
BTW - ditch those 4.10's for 3.55's or 3.42's and I bet peak tq comes down to ~3400rpm.
__________________
Old 08-04-2008, 09:15 AM   #13
DirtyDaveW's Avatar
Dunno if I really want more power on my street car. It's absolutely hairy to drive at peak power as it is. I killed two 600cc sport bikes last Saturday night and it wasn't even a close contest. I admit those are small. I used to have a GSXR 1100 and a Ducati 916SS so those would be a better match. Just gotta go hunting for some liter bikes I guess
Quote:
__________________
Old 08-04-2008, 09:36 PM   #14
RealQuick
Supporting Vendor
I'd check your tune/logs... seems like you hit 400rwtq @ 5psi at 3000rpm, then you lose tq at 6psi, then hit 400rwtq @ 7psi at 3500rpm. Seems like you have a dip in the tq curve (fuel or spark related since there isnt any tire spin with a dynapack).
__________________
Old 08-04-2008, 09:42 PM   #15
DirtyDaveW's Avatar
Yes. It was odd in that way. It did exactly the same on both pulls though. The graph lines are very smooth, like ocean swells. I'll see if I can get the sheets scanned so I can post them.
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1996-2010 CamaroZ28.Com. All rights reserved.
Forums Directory
