Old 07-31-2008, 08:05 PM   #1
dacook
?Correlation between HP & economy?
I'm confused about HP & economy. Common sense would suggest they should have an inverse relationship, yet:
1) My '02 turbocharged SS routinely got 17-18 mpg around town, 22-23 mpg freeway. It dynoed at 436 RWHP. I'm sure the flywheel HP would have been ballpark 500.
2) The 5th gen. V8s are supposed to get 23 MPG at "only" 400-422 ENGINE HP. At the rear wheels they're probably going to come in at 330 or so. (exact # doesn't matter for this question, it will be less than 400)
This begs the question: why did I get better HP per MPG with my SS?
Another example:
The 5th gen. V6 is supposed to get 26 MPG with a 300 HP engine.
I just finished filling up my '05 Impala (3400 engine). I got 25 MPG mostly highway miles. I don't know what the HP is on that engine but I know it's WAY south of 300.
Can anyone give me a good explanation for these seemingly anomalous observations?
-How does the V6 5th gen. get better MPG AND have considerably more power than my Impala?
-Why did my turbocharged SS get as good MPG as the upcoming V8 5th gen. AND have considerably more power?
Hmmmm?????
(Another question I'm kicking around now is why in the heck did I sell that SS )
dacook is offline   Reply With Quote
Old 07-31-2008, 11:47 PM   #2
Steve0
Steve0's Avatar
Send a message via AIM to Steve0
Its a cominbation of things which lead to fuel economy. Engine efficiency and power curve, gearing, weight, rolling resistance and aerodynamics to name a few. Depending on the combination of variables you'll get different fuel economy.
Few other points:
- Your turbocharged engine uses fuel according to how much boost is being fed to the engine amongst other variables. Its not neccearily a direct comparison to compare a forced induction motor to a naturally aspirated one.
- The new SS is geared shorter than the 4th gens were which can have an adverse affect on fuel economy is some 400lbs heavier. If it gets the same highway fuel economy that the 4th gens got in real world conditions, I'd be super impressed.
- The EPA ratings are not going to be 100% what you see. Here's a decent article on the prodcedures.: http://www.epa.gov/fueleconomy/420f06069.htm
The important thing to know is that its just a standardized test used to compare vehicles. I'm sure people will exceed whats on the window sticker for the highway. City wise, its hard to say... with a driver youre talking 4000lbs of SS to push around.
__________________
2008 Mazdaspeed3 Not stock...
1995 Camaro Z28 Bolt-ons, hotcam
1977 Camaro Type LT Slow.
Picasa Blog
Steve0 is offline   Reply With Quote
Old 08-01-2008, 03:57 AM   #3
TrickStang37
Quote:
Few other points:
the GEARING
may be shorter, but coupled with the tire/wheel size, the gearing as a whole is pretty horrible for performance (better for fuel econ).
BTW, if the drivetrain losses for the new SS is the same as the corvette, then the camaro should be making ~350rwhp for the A6 and ~370-375rwhp for the M6.
TrickStang37 is offline   Reply With Quote
Old 08-01-2008, 08:36 AM   #4
skorpion317
Two words: direct injection. More power, better fuel economy.
__________________
1998 Camaro 3.8L M5 - Some bolt-ons, !Rear seats, '93-96 tail light conversion
15.269@90.84 MPH
2009 Malibu LS
2010 Camaro SS/RS M6
skorpion317 is offline   Reply With Quote
Old 10-11-2008, 01:20 AM   #5
Snap50
I've noticed that mileage is directly related to weight pushed and rpm.
Our C5 generally got 20 or better even though pushed hard most of the time, and the Tahoe with 25 less hp, variable displacement but 1500 more pounds is generally 16 or so driven lightly in the same places. Those differences are maily weight biased.
Snap50 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
