pinion play
Old Jul 28, 2008 | 02:28 PM
C5042081's Avatar
pinion play
95 10bolt 2 series carrier
I am installing 4.10, The pinion bearing was pressed, crush sleve in, all new bearings/race , there is still play after tighten nut w/ washer.
Not sure what to do/look for I did use the stock shim
Old Jul 28, 2008 | 03:15 PM
RUDEDOG's Avatar
There should be some play depending on the amount of backlash. If you still have play front to rear you haven't crushed the sleeve yet.
Old Jul 28, 2008 | 04:24 PM
C5042081's Avatar
ya the play is from front to rear, i used a impact gun but didnt go to crazy, from what i read its bad to over tighten the nut.
Does it matter which way the crush sleeve goes on?
Old Jul 28, 2008 | 08:57 PM
jay_lt4's Avatar
that is why it is called a crush sleeve
you need to keep tightening the pinion nut until you reach your pinion bearing pre-load, new bearings 25 inch pounds of rotating force, use a inch pound beam style torque wrench
you need a quality 1/2 impact gun and a little gear lube on the threads helps too
if you go past the desired pinion bearing pre-load, you will need to start over with a new crush sleeve, they are a 1 time use only
Old Jul 29, 2008 | 07:14 AM
cause4panic's Avatar
Throw the damn cush sleeve away. They are not needed, complicate the install and did i say NOT NEEDED.
Old Jul 29, 2008 | 09:14 AM
jay_lt4's Avatar
it is a very easy set up procedure to use a crush sleeve, and if you can not get the crush sleeve to work out you can use a solid pinion spacer (i use these on all high hp cars/trucks)
Old Jul 29, 2008 | 03:24 PM
C5042081's Avatar
kool thanks for everyones help, I put some more tq to the bolt and it tightened fine, I didnt realize how much it took to crush the sleeve
Bxlt1
Sep 10, 2015 08:16 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
350350
14
Aug 11, 2015 12:03 PM
Cam's maro
Aug 11, 2015 07:45 AM
Aug 7, 2015 01:26 PM
