How mod friendly will the L99 be???
Old Jul 27, 2008 | 10:17 PM
GMRULZ's Avatar
More specificly, how will the active fuel management effect internal engine modifications? Can you still put a cam in it ect??
Old Jul 28, 2008 | 03:15 PM
blue 79 Z/28's Avatar
id like to know this also, if it hinders mods i will not get the 6 speed auto even though i want it.
Old Jul 28, 2008 | 03:29 PM
GMRULZ's Avatar
Same here.
Old Jul 28, 2008 | 03:56 PM
TrickStang37's Avatar
The L99 may have solid valves vs. the hollow valves of the LS3. you may have to change the valves or put in some REALLY heavy springs (expect to change them periodically) if your planning a cam.
Either way, the way manufacturers have been cracking down on custom tunes, be prepared to lose warranty on the transmission and engine. apparently they (GM) can tell if it's had a tune, regardless if you put the stock tune back in. they can even tell if the ECM has been swapped. check the corvette boards.
Old Jul 29, 2008 | 03:04 PM
Grape Ape's Avatar
A taller cam will almost certainly require a no-AFM tune like it does in the G8's L76.
mark0006
Sep 14, 2015 12:35 PM
Bxlt1
Sep 10, 2015 08:16 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Aug 17, 2015 03:55 PM
CARiD
Jul 7, 2015 08:19 AM
