07-25-2008, 01:11 PM
Dry Sump Oil System in 2010 SS?
Haven't seen all the specs on the new SS, but will it have a dry sump system? I saw where the motor takes 8.9 qts of oil. Just wondering. I've got an old 78 Z that I may have to trade in for the SS.
07-25-2008, 01:21 PM
Quote:
99.9% sure it's not gonna have an expensive dry sump system and if I'm not mistaken the LS3 uses 6 quarts although I could be wrong.
__________________
Forget gold, the next currency will be lead!
07-25-2008, 01:25 PM
Super Moderator
Quote:
GM's specification document says that the LS3 and L99 Camaros will need 8.9 quarts of oil. Could be a typo -- maybe it's supposed to be 5.9?
Just for comparison's sake, the LS1 and LS2 use 5.5 quarts of oil.
__________________
2002 NBM Camaro Z28 M6 - best ET 13.21, best MPH 108.9, best 60' 2.14 - 325hp/343tq - Lid, Corsa, SixSpeedsInc T56, Pro 5.0 w/ short stick, 17x9 wheels
1987 Buick Grand National - best ET 13.66, best MPH 101.5, best 60' 2.08 - 253hp/334tq - 93 chip, RJC, meth, Hooker catback, 160 t-stat, shift kit, no-hop bars
07-25-2008, 03:10 PM
just FYI, after working at a dealership, I can honestly say you with a straight face that you will get $100-$500 for your old 78 Z(28?). If its in GREAT condition, maybe they'll bump you up to $700.
07-25-2008, 03:32 PM
Premium Member
the coupe/convertible ls3 vette take 5.5/5.2
and the Z06 takes 8/7.5
source : http://www.thevettenet.com/2008Specs.pdf
take it however you want
07-25-2008, 03:59 PM
No, its 8.9 qts. I belive GTO's LS1 and LS2 had a massive oil pan as well. I dont know wtf for, but 9 qts x 6.50 a quart of Mobil 1 or Q 5w30 gets expensive!!!
9 qts is 1 qt short of the Z06 and ZR1's 10 qt dry sump system.
I dont remember reading anything about dry sump. If that is teh case, that kinda sucks. You wont be able to do your own oil change anymore unless you have some sort of vacuum machine....
__________________
2009 Malibu LT 2.4: My NEW Ride! Yeah...no Camaro...I know I know...
1987 Camaro Z28
1972 Camaro RS: It's easy being green
Mod @ GMInsidenews.com
07-25-2008, 04:57 PM
Good info guys. Just joined the website. It's a good one. If I decide to buy one of these bad boys I probably will sell the car outright. It's in rough shape, but I still had offers of $2,000 over the winter. I've had the car since 78, bought it brand new and haven't parted with it yet cause I know I'll be kicking myself if I do. Real excited about the new SS, but don't know if I can afford one (one kid in college, another one 2 yrs away). Was questioning the oil only because the amount seemed extreme. Can wait to see one in the showroom. Have a good weekend ...
07-25-2008, 06:58 PM
It is to compensate for the 4 qts you will burn every 3000mi
07-25-2008, 08:30 PM
I thought it was a typo as well, but the V-6 numbers are high also.
07-25-2008, 10:06 PM
G8 GT takes close to 9qts.
__________________
2008 G8 GT
2000 Z28
08-02-2008, 11:41 PM
Premium Member
My LS2 actually calls for 6.5 qts of oil with the filter installed.
08-03-2008, 04:04 AM
the LS3 in the corvette says between 5.5 and 6 qts with filter, depending if it has an oil cooler or not.
The LS7 uses 8.
08-05-2008, 02:50 AM
Hmmmm.... I'm pretty sure its a wet system but I suppose the increased capacity ranges from decreased oil change intervals to possibly using the increased capacity to offer more stable oil temps, or maybe even just to make sure there are no starvation problems in the twisties. However I'll go with my first guess as the most probable. I know Ford went with 6 quarts in the new GT and 5k change intervals instead of 3k intervals and 5 quarts.
__________________
Quote:
I used to work with this old German engineer, who would respond to predictions of the demise of the internal combustion engine with the following: "The hearse that drives you to the graveyard will have an internal combustion engine". - some guy on a forum.
08-05-2008, 10:56 AM
Premium Member
Quote:
I resent that!!!  My car didn't start burning oil 'til after I changed my 'verter. Now, I can go through about a quart in 3K miles. It's not bad, just a little disappointing.
__________________
-Chuck (your resident Z28 fanatic) Yes, I'm Hell-bent on a supercharged Z28! ( please GM)  2002 Z28 NBM A4 3.23 Lid, C.B., stall, some suspension - 12.6 @ 109 1.6X 60' - all over the limiter
08-05-2008, 10:58 AM
Premium Member
Quote:
I'll buy this one. It's hard to believe how much oil actually contributes to cooling the engine, not just for lubrication. I've read an engine can, under some circumstances, run for minutes, without oil in the pan. I imagine GM will probably suggest 10K oil changes with that amount of oil in the engine.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
