07-23-2008, 12:06 AM
Usb?
In the specs it says it has "usb connectivity". Does anyone know what this means? Could it mean you will be able to hook up your ipod and control it through the stereo buttons? That would be freaking awesome.
__________________
Teal '95 Z28 A4
Mods: K&N Air filter, !TB, manual fan switch, 160 deg. therm, and I took out that little thingy that doesn't let you shift into 1st. (I'm such a loser)
07-23-2008, 01:50 AM
Quote:
Originally Posted by Gm Chat
BitchinCamaro: What models is the USB port available on, and is it just for iPods?
JohnFitzpatrick: I believe any jump drive can fit in the USB. It will have to have MP3 files to be read, however.
You probably won't be able to use an iPod, since they are AAC files. Maybe if you load your iPod in 'disk mode.'
__________________
2002 Z28
2010 2SS/RS - #7881 - IBM/Black
07-23-2008, 10:14 AM
Did they say anything about just a normal 3.5mm stereo plug anywhere?
__________________
Teal '95 Z28 A4
07-23-2008, 01:14 PM
Quote:
Yes, in the storage area of the arm rest console there is an aux 3.5mm jack.
08-05-2008, 02:33 AM
Quote:
Have you not heard of iPods being called an mp3 player? They also use mp3 compression so yes, you could use one theoretically.
12-22-2008, 11:18 AM
Cars with USB all use iPods. I mean think about it, they don't put it in there just to play music off a flash drive.....iPod is the reason for the usb connection...
03-23-2009, 08:59 PM
im pretty sure its an extra cost i do believe like 500 for usb n extra odd stuff for it wasnt payin it but i dont know if its free for a higher end model havent looked i would like it though
04-10-2009, 02:20 PM
Actually that is one of the designs, it should be able to play mp3's straigt from a flash drive, ipod maybe, since it does aac, same with Zune, since that is wma, guess i need to do some more research myself on it.
__________________
96 TA a4, Flowmaster muffler, K&N cold air kit, ported maf,180 t-stat, throttle body bypass.
13.95 at m6
04-23-2009, 11:51 AM
The USB port is in the glove box. It will work with iPod, Zune, flash memory sticks and most MP3 players. They can be controlled from the steering wheel audio controls too. Portable hard drives aren't reccomended but it's possible they would work too if in FAT32 format. It can also sync from your blackberry through bluetooth and play music from there.
__________________
Quote:
Originally Posted by Fbodfather
Wanna get rid of that Mustang and buy a REAL performance car?????
04-23-2009, 06:18 PM
For those who haven't seen it yet, here is a GREAT shot of what the USB/3.5mm jack looks like and where it is located in the center console:
04-23-2009, 06:43 PM
Standard on the 2LT and 2SS - OPTIONAL on the 1LT
(Not on the 1LS or 1SS)
04-25-2009, 10:03 AM
It will not synch up with Palm Pilots.
I tried.
__________________
2009 Challenger R/T; 2007 Solstice GXP
2004 Colorado ZQ8; 2002 Trans Am C/E;
1994 Grand Prix SE B4U
04-25-2009, 06:56 PM
Premium Member
Quote:
that really annoys me
__________________
2008 Z06 - black/black, comp gray wheels, mild to wild switch
SOLD 1994 LT1 - forged 357, heads, cam, GMMG cat back and other stuff
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
