Old 07-20-2008, 02:20 AM   #1
Nightshade
Nightshade's Avatar
Question AFM Mandatory?
There hasn't been any word yet if it's just an option, or if it's a function that can't be avoided like the current Impala SS.
I know how it works and that it doesn't affect performance, I'm just worried about long term wear & tear on the engine. Such worries as cylinders wearing unevenly, or worse yet, will it get stuck in 4cyl mode after 100k miles? Just something I don't want to risk if I'm going to spend 40k on a car.
Nightshade is offline   Reply With Quote
Old 07-20-2008, 02:49 AM   #2
Big Als Z
First off, the engine wear will be the same. The piston doesn't stop moving.
Second, if all else fails, the car goes into full V8 mode, and cannot get stuck in 4 mode.
Can you avoid it? I dont think GM wants you to. AFM could get the 6spd autos out of any type of gas guzzler tax, much like the manual trans skip shift feature.
__________________
2009 Malibu LT 2.4: My NEW Ride! Yeah...no Camaro...I know I know...
1987 Camaro Z28
1972 Camaro RS: It's easy being green
Mod @ GMInsidenews.com
Big Als Z is offline   Reply With Quote
Old 07-20-2008, 10:14 PM   #3
AdioSS
Send a message via AIM to AdioSS
I still want a switch AFM ON/AUTO/OFF that gives the driver control.
Auto is how it is originally shipped.
ON makes the engine run in 4 cylinder mode all the time.
OFF makes it fire on all cylinders.
__________________
ChestonPhillips@yahoo.com
Quote:
Originally Posted by Bob Cosby View Post
Now we're speculating on the speculation....all the while, throwing more speculation into the mix. Is one speculation (or "most realistic guess") any better than the other speculation?
AdioSS is offline   Reply With Quote
Old 07-20-2008, 11:09 PM   #4
MetalDragon
MetalDragon's Avatar
Send a message via Yahoo to MetalDragon
I think I see the reasoning behind this. If I were to want to putt around town and conserve fuel, then I could leave it in 4cyl mode. If I wanted to run harder, I could put it back in auto.
HOWEVER....if this car weighs what we think it will, or even in the 3700 pound range, the gas mileage would suck in stop/go driving. Too small an engine would have as adverse effect on mileage as too much engine.
MetalDragon is offline   Reply With Quote
Old 07-20-2008, 11:20 PM   #5
DvBoard
If such a switch was included it would only have Auto/Off modes. This being because i don't believe it can idle correctly @ 4 cylinder mode, as well as to keep idiots from complaining about not getting 4 cylinder gas mileage while putting up with the crappy performance of the 4 cylinder running of a V8 engine.
__________________
/ OR . Traitors...
DvBoard is offline   Reply With Quote
Old 07-21-2008, 02:49 AM   #6
Nightshade
Nightshade's Avatar
Still doesn't exactly answer my question. Does anyone have a high mileage vehicle with an AFM equipped V8? I want to know how it wears or if it is any more problematic than the norm of running on all 8 cyl.
Old 07-21-2008, 11:02 AM   #7
Eric77TA
There are probably some high mileage ones out there somewhere.
Like Big Al said, the pistons don't stop moving, though the valves do. I really can't see where AFM would cause any more wear than normal use.
A failure in the AFM management is probably no more or less likely than a failure in any of the other hundreds of electronic functions going on at any one time in a modern automobile.
I think the only way to avoid AFM will be to get the manual.
__________________
1977 Pontiac Trans Am
2006 Chevrolet Cobalt LS (Daily Driver)
2007 Saturn Vue Green Line (Wife's car)
Eric77TA is offline   Reply With Quote
Old 07-21-2008, 11:43 AM   #8
Big Als Z
It does have a switch. Its in front of the driver, to the right of the brake pedal.
Stay out of it, it will be in 4cyl mode.
Talk to anyone that has driven a Impala SS, LaX Super, any Silverado with a 5.3. So far, I have heard zero problems. Again...if it fails, it fails into V8 only mode. It has to turn ON to shut down the lifters. If it never turns on or if the sensor fails, it wont stop the oil from going to the lifters.
I do wonder if the LS3 will be available at an extra cost option for Autos, on top of the fact that the car could see a gas guzzler tax.
__________________
1987 Camaro Z28
Old 07-22-2008, 12:27 AM   #9
Nightshade
Nightshade's Avatar
Alright, I think I got it now. This is all good because I was originally planning on getting a manual transmission anyway. And thanks for the info on how AFM works, GM really doesn't explain it all that well. Hence my confusion.
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
