09-14-2002, 01:38 AM
LS1 fuel tank in an LT1 car
I was wondering if the two tanks are interchangeable? LT1 is steel and 15.5 gallons and the LS1 is plastic and 16.5 gallons. The lines and electric conn. look the same.
TIA
Lewis
__________________
LewisW.
'96 Trans Am
09-14-2002, 09:10 AM
Depending on where/how the tank was made bigger, one thing that might be an issue is if the pickup on the pump will reach that extra gallon of gas.
Another thing is that this will really mess up responses to the posts "How many miles per tank do you get?".  (another reason not to ask that question)
Rob B 95Z A4
Tech Page
09-14-2002, 10:52 AM
My tank has a large dent in it but is not leaking. The gauge also reads fun. I was going to just put in tank pump and al in with the new LS1 tank.
Thats why i was asking?
Lewis
__________________
LewisW.
'96 Trans Am
09-14-2002, 12:34 PM
Good idea! I'm curious, too.
-Chris
__________________
Onyx Black '95Z: 355 LT1, HKS 76.5mm turbo, 3400 stall, built 4L60E, 12-bolt, 315/30/18s
'64 Impala Sport Coupe: 300 horse 327, soon to be bagged on 20s.
'69 Camaro RS/SS; 375 horse 396/4-speed, factory 12-bolt. Restoration project.
Something wicked this way comes...
09-14-2002, 06:40 PM
Hmmmmmm........added benefit of the weight savings with a plastic tank!
I wonder what the wieght savings will turn out to be?
When you have both tanks sitting on the ground - see if you can somehow weigh them to see for us.
This may turn out to be a good weight reduction mod if it's quite a bit.......
__________________
1997 Red Zed M6
K&N Intake, Dynomax Exhaust, MSD6A Ignition and B&M Ripper
09-14-2002, 11:26 PM
I am not sure, but I think the LS-1 has a different width trunk space than the LT-1. Therefore, the tank might be formed fit for the particular vehicle.
1997 Camaro SS #2948
M6, !CAGS, T-Tops, Tinted Glass
17x9.5 Boyd Coddington Shysters
Eibach Sportline Springs
Flowmaster Exhaust
Pic coming soon!
09-15-2002, 01:11 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Srper:
</font>
There are'nt any structural changes on the 4th gen. f-body's.
BLACK 97' RAM-AIR TRANS-AM, DEEP TINT,
LINGENFELTER 383 LT4,
6 SPD. TRANNY, CENTERFORCE CLUTCH, HOOKER LONGTUBES, FLOWMASTER CAT-BACK, STOCK WS6 HIGH POLISHED WHEELS WITH THE REARS WIDENED TO 11 INCHES WEARING 315-35-17
G-FORCE TA's, 2 INCH SUSPENSION DROP VIA EIBACH SPRINGS AND KONI SHOCKS, HARDER DUROMETER BUSHINGS EVERYWHERE ON THE CAR, LS1 CALIPERS AND 13 INCH CROSSED-DRILLED ROTORS, DOUBLE DIAMOND SUB-FRAME CONNECTORS, LG MOTORSPORTS REAR LOWER CONTROL ARMS, STRUT TOWER BRACE, TORQUE ARM, AND ADJUSTABLE PANHARD ROD
__________________
BLACK '97 WS6 RAM-AIR TRANS-AM, DEEP TINT, 396 LT4, 6 SPD. TRANNY, PRO 5.0 SHIFTER, HOOKER LONGTUBES, FLOWMASTER CAT-BACK, STOCK WS6 HIGH POLISHED WHEELS WITH THE
REARS WIDENED TO 11 INCHES WEARING 315-35-17 TIRES, 2 INCH SUSPENSION DROP, LS1 CALIPERS AND 13 INCH CROSSED-DRILLED ROTORS
Pics of my car and 396 c.i. LT4
09-15-2002, 01:51 PM
I'll talk to my salvage guy in the morning and see what he says.
__________________
I have Two Camaro's and they both run!!!
09-15-2002, 02:08 PM
its 16.8 gallons.. if you want to be technical..
:P
also the gauge light comes on in an ls1 when it gets to about 3 gallons left.
In my LT1, the E meant get ready to push. 5 times I found myself pushing or walking with my trusty 1 gallon gas can I kept in the trunk.
__________________
Psycho Cabbage
2002 Camaro Z28/FLS6B(5-02) - (6 sp)
Bone Stock and Cruise Control equiped Stripper!
My Page
09-15-2002, 02:14 PM
I don't know if the low fuel light will come on or not, but the extra gallon or so of gas would be a plus. I not think the wieght diff. is going to be too great. I figured my gauge is bad and I also have a large dent on the corner of my tank. I would be able to fix both in one shot.
Lewis
__________________
LewisW.
'96 Trans Am
09-17-2002, 07:39 PM
Well I think I'm going to try it.
Lewis
__________________
LewisW.
'96 Trans Am
09-17-2002, 10:38 PM
The LS1 in the F-Car uses a "Returnless" fuel system. It has a return but it is back near the tank. It may still work, let us know.
09-17-2002, 11:07 PM
i dont have any experience of my own to back it up, but somebody on LS1tech.com said they weighed both tanks and that the plastic tank is 18lbs lighter than the metal tank
09-18-2002, 01:04 AM
 Wow.........that much lighter......... As soon as someone knows whether the swap will work, let us know...
__________________
1997 Camaro SS #2297
396 LT1, 4L60E, Callies Crank, JE Pistons, Crower 1.6 RR, Comp R Lifters, AFR Hyda-Rev, Canton Oil Pan, Meziere WP, 58mm TB, Yank PT 4200, 1LE DS, Hawker Battery(13.5 lbs), Hooker LT's, 4" Mufflex, OBD1 Conversion, Spohn TA & LCA's, HAL Shocks...
www.LT1MOTORSPORTS.com
09-27-2002, 10:03 PM
Any progress?
Anybody tried this yet?
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
