Squeeky Brakes
Old Dec 25, 2002 | 10:16 PM
DevilsAddvocate's Avatar
Squeeky Brakes
Guessin Pads Need Replacin, right?
Old Dec 25, 2002 | 10:53 PM
DanD 96 SS's Avatar
My experience has been if they squeak when driving without the brakes on then the metal scrapers for the warning of low brakes is rubbing which means time for new brakes. If the brakes squeal when applied then you have to put the anti squeak lube between the pads and the caliper. When I change brakes I put that pliable gasket-sealant on the back of the brake pad, never had a squeal yet. Hope this helps
Dan
Old Dec 26, 2002 | 09:56 PM
aklim's Avatar
You sure the rotors are not warped at all?
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
