Keyless entry/remote
Old Jun 24, 2008 | 07:56 PM
canuck94z28's Avatar
Question Keyless entry/remote
Ok here is a brief update:I can open the driver,s door w/the remote and lock it also but when i try the pass.side i hear a sound but the door doesn,t unlock!The thing is ,if i use the switch on the driver,s door both doors will lock/ unlock.My problem seems to be w/the remote(like the pass.side isn,t programmed or something)I also just put new batteries in the remote.Any info.etc would be most appreciated.
Old Jun 24, 2008 | 09:20 PM
shoebox's Avatar
Probably the keyless entry receiver. Mine works sporadically, too.
Old Jun 25, 2008 | 01:36 PM
Slick_Sammy's Avatar
same here. could i pull one of those receivers out of any yr model 93-97 and would it work on a 94? remotes should be able to be reprogrammed easy i assume. might search the junkyard for a spare.
Old Jun 25, 2008 | 11:30 PM
shoebox's Avatar
94-95s would be the only ones to have them.
Old Jun 26, 2008 | 05:53 AM
bmotwani's Avatar
mine is an aftermarket and i've given up on it; cos its taken a life of it's own. It locks but never unlocks. It will only unlock immediately after locking (within 3 to 4 seconds). Wierd. No explanation.
Old Jun 26, 2008 | 10:21 PM
Thanks for the reply SHOEBOX.I will try to check that receiver.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
gelbza
May 29, 2015 05:50 PM
silver97Z
Aug 18, 2003 12:53 PM
CamaroZBoy
Apr 26, 2003 12:01 PM
