service on 99 SS
Old Jun 19, 2008 | 01:32 PM
1999 hugger's Avatar
service on 99 SS
I have a Orange 99 SS with white top and white leather. I have 90k on the car and have changed the oil every 3,000 miles. I have not done other service except a couple of minor items and a brake job. I am going to keep the car because it is still tight however can anyone tell me what services I need to have done to insure future reliability? Thanks for your insight.
Old Jun 19, 2008 | 02:07 PM
vonmoldy's Avatar
Do you realize you posted this in the 2010 Camaro Powertrain Discussion forum?
Your car is about 11 years too old so if it has a 2010 Camaro motor in it please post some pics.
Old Jun 19, 2008 | 02:38 PM
JasonD's Avatar
Admin Emeritus
Moved to the more appropriate forum.
Old Jun 19, 2008 | 04:02 PM
DrRuckus13's Avatar
My $.02
Replace spark plugs at 100K
Replace the plug wires at 100K
Replace the o2 Sensors at 100K
Change your Oil and filter at 3K
Change your air filter at 15K
Change your PCV valve at 75K
Change your Fuel Filter at 100K
Change your coolant every 2 years
Change your transmission filter and fluid every 30K
Change your Rear Diff fluid at 30K
Flush your power steering fluid at 100K
Flush your Brake Fluid every 2Years
Old Jun 19, 2008 | 04:31 PM
JakeRobb's Avatar
Super Moderator
I'll second the above. Some of that is pretty **** (you could probably get away without ever flushing your brake fluid), and I think GM's recommended transmission fluid change interval is 75,000 miles, but other than that, looks good.
Old Jun 19, 2008 | 05:59 PM
Thanks, I appreciate the advise and scheduled the 90K service and secondary tuneup.
Old Jun 20, 2008 | 12:31 PM
98supersport's Avatar
I'd plan on doing the fuel filter between 15-30k intervals. It's not difficult to replace, and keeping a clean filter on will possibly add some life to your fuel pump. Replacing your fuel pump is NOT cheap so this is like cheap insurance... that and never running the car super low on gas (which allows the pump to overheat).
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
plattted
9
Sep 20, 2015 11:23 AM
