Old 06-18-2008, 11:38 AM   #1
Gripenfelter
Premium Member
Gripenfelter's Avatar
Send a message via ICQ to Gripenfelter Send a message via MSN to Gripenfelter
Why not a turbo V6?
I've been joking around for a while now about a "Maximum Bob" turbo V6 but I think with the current gas prices a turbo V6 could actually attract a lot of buyers.
Base 300 hp DI V6 and a 400+ hp turbo V6.
__________________
'93 Z28. Engine?? Horsepower?? New powerplant coming in 2010.
'05 GTO MBM SAP M6= RWD GRAND AM!!
Pics of my 3" duals My Homepage with T-top conversion guide
Order your 2009 Camaro from Jason Debler and beat the dealer mark ups!
Gripenfelter is online now   Reply With Quote
Old 06-18-2008, 01:47 PM   #2
Dragoneye
I'd buy it.
__________________
Quote:
Originally Posted by CR97WS6 View Post
If you want to buy something else then do it, but you'll be jealous when that 5th gen passes your @ss and all you can do is drool!
"Keep the Faith."
Dragoneye is offline   Reply With Quote
Old 06-18-2008, 01:52 PM   #3
JakeRobb
Super Moderator
JakeRobb's Avatar
I already own a turbo V6. Love it. The turbo V6 F-body has been done ('89 Turbo TA), and was/is awesome. GM should do it again!
Having said that, a naturally aspirated V8 must be on the option list.
__________________
2002 NBM Camaro Z28 M6 - best ET 13.21, best MPH 108.9, best 60' 2.14 - 325hp/343tq - Lid, Corsa, SixSpeedsInc T56, Pro 5.0 w/ short stick, 17x9 wheels
1987 Buick Grand National - best ET 13.66, best MPH 101.5, best 60' 2.08 - 253hp/334tq - 93 chip, RJC, meth, Hooker catback, 160 t-stat, shift kit, no-hop bars
JakeRobb is offline   Reply With Quote
Old 06-18-2008, 03:18 PM   #4
STOCK1SC
Given the choice between a 400hp turbo 6 and a 400 hp NA V8, I'll take the turbo 6, it will be faster and get better mileage(not much but maybe 1-2) and be easy to mod granted it isn't made out of glass. Not to mention it will probably be lighter, again not by much but 100lb's is possible.
__________________
Forget gold, the next currency will be lead!
STOCK1SC is online now   Reply With Quote
Old 06-18-2008, 03:45 PM   #5
metal
I have two Turbo6 F-Bodies (89 Turbo T/A and a 92 Z28 I converted) you know I'd be all over it.
A GM ad with a GN fading into a 5th gen with the tag line like "We did it again..." would be great!
__________________
Current Ride's
92 Z28 1LE Z03 LC2
98 Z28 Bone Stock
89 TTA #1025
Past Rides
89 TTA #1415
89 TTA #891 RIP
81 TTA Nascar
91 TA Vert T5 WS6 G92 LB9
metal is offline   Reply With Quote
Old 06-18-2008, 06:02 PM   #6
mike24
Put me down for one
__________________
Future 2010 Camaro Owner
Old Rides:
Silver 1998 Firebird Formula WS6 M6 Sold
Silver 2000 Firebird V6 14.76 @ 91.98 Sold
mike24 is offline   Reply With Quote
Old 06-23-2008, 03:13 PM   #7
Aaron91RS
turbo cars don't really get any better mpg then there couterpart NA V8 cars.
Therefore I can't see a reason for GM to do it.
__________________
http://www.team3rdgen.com - all welcome
Writing tickets really doesn't make the world a better place
LS1/T56/9" - in a 3rdgen of course
7.4L Y84 WS6 'bandit'
Aaron91RS is offline   Reply With Quote
Old 06-23-2008, 03:33 PM   #8
JakeRobb
Super Moderator
JakeRobb's Avatar
Quote:
Why would it be faster?
__________________
Old 06-23-2008, 03:41 PM   #9
Jason Dove
Quote:
Because of the blow off valve noise.
__________________
Jason Dove
'95 Dark Metallic Purple Z-28 on '98 Z-28 Rims
383 w/9.5:1 compression, LT4 MTI Ported Heads and Intake, CC305, 12 Bolt and an M6 Swap.
Jason Dove is offline   Reply With Quote
Old 06-23-2008, 08:25 PM   #10
Grape Ape
I don’t think it will be meaningfully lighter (or heavier), although the weight should be a little farther back.
But the modern Turbo, DI, VVT engines (LNF and the 6 in the 335) have flatter torque curves than anything I’ve ever seen attributed to a NA V8.
Grape Ape is offline   Reply With Quote
Old 06-24-2008, 08:29 AM   #11
STOCK1SC
More torque than a NA V8 can make. GN's made more torque with 3.8l than Corvette's did with 5.7l.
__________________
Old 06-24-2008, 04:37 PM   #12
Grape Ape
Sky Redline (2.0 with DI and a turbo): 19/28 MPG & 260hp
Base Sky (2.4 NA with port injection): 19/25 MPG & 173hp
I can only assume that a Sky with a LY7 (3.6 port injection V6) would get worse mileage than either of the fours do to parasitic losses.
I think that a twin turbo V6 Camaro could actually return better mileage than the base (NA) V6.
Old 06-24-2008, 09:29 PM   #13
81Z28355
Why would it need to be a twin turbo? The Grand Nationals did'nt seem to need more than one 20 years ago to beat up on most other cars on the road.
81Z28355 is offline   Reply With Quote
Old 06-25-2008, 04:19 PM   #14
Grape Ape
Quote:
It wouldn't need to have two turbos but two small turbos would spool-up faster than one bigger one. That probably wouldn't matter to the drag guys, but I want a daily driver.
Old 06-25-2008, 04:28 PM   #15
Dragoneye
Assuming the base NA V6 is the Direct Injected one....would it? Problem is, GM doesn't have a NA Direct Injected I-4 from which to judge.
I guess my question is, does a modest (OEM) Turbocharger always increase fuel economy?
__________________
"Keep the Faith."
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
