Old 06-16-2008, 12:42 AM   #1
Chevyguy358
383 lt1 dyno video
Here is a short clip of a dyno tune at straightline performance in IL. Its just a mild 383 with around 12:4:1 static and 9:3:1 dynamic compression. The tuner there spent much of the day setting up the parameters, I had to leave it there. Its being tuned for E85 due to the high compression and should be able to pick it up sometime this week. i should prolly update my sig
http://videos.streetfire.net/video/3...yno_166386.htm
The clip is short because if you listen carefully you can hear a slight pop at wot after which we checked the gapping on the plugs and they were too large for this much compression.
__________________
-94 Z28 383 12:4:1 SCR, E-85 converted, forged bottom, ported heads and LE cam, T56 converted
-72 Chevelle SS(clone)- 383 stroker forged bottom, Pro Topline 235cc heads
http://www.cardomain.com/id/Chevyguy358
Chevyguy358 is offline   Reply With Quote
Old 06-16-2008, 09:57 AM   #2
slomarao
Nice, what did it put down?
__________________
95 Silver Z28 m6--323rwhp/338rwtq bolt ons
Trial pass: 2.1 60ft 13.1@109 ---------Rod bolt went, now building a 357: LE cam, cleaned up heads, spec 3, boltons...
slomarao is offline   Reply With Quote
Old 06-16-2008, 10:59 AM   #3
Chevyguy358
no numbers yet...will find out when i pick it up. I will let you guys know how the e85 tuning worked out as i know a few of you were curious
__________________
Old 06-16-2008, 02:40 PM   #4
texas94z
texas94z's Avatar
What kind of gains are you expecting using 12.4:1 static compression w/ E85 compared compared to 11:1 w/ 93+ octane fuel? I am planning to build a high compression nitrous 355 using E85 for my dd.
__________________
1994 Camaro Z28 A4
texas94z is offline   Reply With Quote
Old 06-16-2008, 05:09 PM   #5
hsyr
What kind of mods you got done to the motor other than the bottom end and what kind of HP level are you expecting out of it?
__________________
94-Z28-M6-Red
hsyr is offline   Reply With Quote
Old 06-16-2008, 06:43 PM   #6
Chevyguy358
Quote:
Well its really dependent on the DCR of the motor the higher the DCR the higher the potential for detonation. E85 is around 105 octane allowing for greater timing advance. If tuned correctly with a high DCR or a FI application i would expect 4-5% gains.
On a sadder note the tuner from the shop called today and said that the converter i am using is looser than most and causing a significant slip. Therefore the numbers its putting down arnt that impressive, not to mention its on a mustang dyno. He said he was unable to manually lock it. He did however say that it was putting down 360+ tq at the wheels before he started advancing the timing.
__________________
Old 06-16-2008, 06:51 PM   #7
Chevyguy358
Quote:
LT1 383 SHORTBLOCK –
SCAT 3.75 STROKE CRANKSHAFT
SCAT FORGED 5.7 I-BEAM RODS
SPEED PRO FORGED FLAT TOP PISTONS
TOTAL SEAL MOLY RINGS
CLEVITE 77 bearings
Felpro 1074 head gaskets (.039 in thick)
Custom ground cam .544/.555 lift 230/236 duration 112LSA
1.6 ratio full roller rockers
Ported stock heads with enlarged 2.02/1.06 valves
Has been milled around 53cc chambers (estimate) (12:4 CR)
Ported stock LT1 intake
37lb Delphi injectors flow matched
BBK 52mm throttle body
MSD coil
Meziere Electric water pump
Custom cold Air induction
Exhaust
Pacesetter long tube headers
Pacesetter Y pipe
Loud mouth I exhaust
Borla XR-1 3.5 in muffler
Transmission 4l60E
Rebuilt
Transgo shift kit
ACC Boss Hog 3200 stall converter
Rearend stock 7.5 10 bolt
Rebuilt with 3.73 richmond gearing
__________________
Old 06-16-2008, 07:08 PM   #8
texas94z
texas94z's Avatar
I see. 5 percent gains are not to shabby. Sucks about the converter.
__________________
1994 Camaro Z28 A4
Old 06-16-2008, 07:37 PM   #9
Chevyguy358
If this motor wasn't having slipage through the converter i would ideally expect 380hp/400tq. As far as using E85 there are reports of people gaining much more than 5% but alot of people are relucant to believe it and there are many variables thats why I said 4-5%
__________________
Old 06-16-2008, 10:02 PM   #10
texas94z
texas94z's Avatar
Are you planning to stay NA or maybe some nitrous down the road? I always wondered how nitrous would burn with e85. 106 octane and nitrous would match really well it seems.
__________________
1994 Camaro Z28 A4
Old 06-16-2008, 10:39 PM   #11
Chevyguy358
yea when i get some money again i would like to spray....not too sure about how the E85 would affect that but i know my high compression will love it.
__________________
Old 06-17-2008, 12:59 PM   #12
slomarao
the e85 will love n2o and will do great with it. It is 100+ octane so i would worry about it. I think its 103 or 104. But both the comp ratio and e85 will eat up that juice like nobodies business.
__________________
Old 06-17-2008, 03:45 PM   #13
quicksilver97ta
quicksilver97ta's Avatar
Did you do anything else to the car to prepare for the E85? I've read it eats rubber and is even somewhat corrosive on some metals. Carbed cars have more issue with it having more rubber lines, needle and seats, and floats but I have also read about guys finded corrosion in the fuel bowls as well. I dont know how many o-rings or different metals might be exposed in our FI cars. They already put 10% in regular gas around here but going E85 is a big jump. My combo is similar to yours but I run a bigger cam and just run E10 @ 93 octane. I've thought about mixing E85 though.
__________________
97 T/A, 68 Firebird, 70 Lemans
quicksilver97ta is offline   Reply With Quote
Old 06-17-2008, 10:27 PM   #14
Chevyguy358
Quote:
Nah after researching it I realized that the corrosive nature of E85 is over rated and very few parts in a fbodys fuel sys contains rubber and other degradable materials. I guess i will find out here in a couple years.
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Garage vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2010 CamaroZ28.Com. All rights reserved.
Forums Directory
