lots of 4th gen f-body parts FS in dallas texas
Old May 6, 2008 | 12:03 PM
STS95T/A's Avatar
Here is a list of everything I can think of, feel free to pm me if you need anything not listed
Complete LT1 with all accessories, wireing, and pcm-$1200
Tinted t-tops –$100 each
Tan t-top shades-$25 pair
Dark gray t-top shades-$25 pair
Maroon Camaro manual doors (drivers door has a small crack in it)–$80 pair, pick up only
Ls1 rear brake assembly complete(backing plates, calipers, and rotors)-$80
323 rear end-$200 pick up only
Lg adjustable panhard bar-$80
LG weld-in sub frame connectors with crossover-$80 for all 3 pieces
LT1 e brake cables-$30 set (3)
Ls1 e brake cables-30 set (3)
Lt1 stock k-member-$25 pick up only
Steering rack-$40
93-96 Camaro drivers airbag-$30
95-97 Firebird drivers airbag-$30
93-97 passenger airbag-$25
98-02 passenger airbag-$30
Lt1 brake master cylinder-$10
Lt1 fuel sending unit-$40
A4 automatic shifting linkage with all cables-$40
A4 pedal assembly with all sensors-$40
Lt1 radiator/fan support/shroud-$25
Lt1 front calipers-$20 pair
Firebird/trans am radio bezel-$10
Ten bolt diff cover-$10
Gray A pillars-$20 pair
Gray B pillars-$10 pair
LT1 MAF-$30 descreened, $40 screened
E brake handle assembly in gray-$25
LT1 fuse block cover ( under hood)-$10
96-02 V6 starter-$40
LT1 brake booster-$20
LT1 water pump-$30
LT1 stock cam-$25
LT1 accessory bracket-$40
98 airbag sensor-$25
93-95 airbag sensor set (3)-$25
96-97 airbag sensor-$20
Black Camaro beager panel-$40
93-97 Camaro complete headlight bar-$80
Lt1 starter-$40
Dual horn assembly-$25
Black Camaro side mirrors-$20 each
Rear view mirror-$20
Rear hatch lock assembly-$10
Gray dome light-$5
Tan dome light-$5
Stock lower a-arms-$15 each
Front hubs-$10 each
M6 aluminum drive shaft-$100
A4 steel drive shaft-$30
Stock torque arm-$25
93-95 Firebird dash (not upper dash pad)-$80
96-02 gray Firebird dash (not upper dash pad)-$80
93-96 Camaro dash (not upper dash pad)-$60
93-96 Camaro HVAC controls-$20
Firebird HVAC controls-$20
93-96 Camaro headlight controls-$15
Firebird headlight controls-$15
Camaro window/mirror/lock controls with bezel-$40 pair
Firebird window/mirror/lock controls with bezel-$40 pair
LT1 motor mounts-$30 set
Light gray seatbelts front and rear-$60
LT1 radiator-$80
Lt1 fan assembly-$80
93-97 V6 radiator-$50
98-02 V6 radiator-$50
1 LT1 rear caliper-$20
93-96 150 mph camaro gauge cluster with 120k and 151 k miles-$30 each
93-97 formula/trans am 110 mph cluster with 125k miles-$25
98-02 Firebird 125 mph gauge cluster with 134k miles-$30
White 93-97 Firebird front bumper-$40 pick up only
White Firebird hatch-$40 pick up only
White 93-97 Firebird hood-$40 pick up only
Red Firebird Rear bumper-$30 pick up only
Red Firebird hatch-$40 pick up only
Black Z28 hatch-$40 pick up only
All prices are obo and without shipping
I’m located in mansfield tx 76063
My paypal/e-mail is f-bodyparts@hotmail.com
Thanks
robbie
Old May 6, 2008 | 12:10 PM
texasTA's Avatar
How about 60.00 for the Firebird hood and the 120k 150mph gauge cluster? I can come this weekend.
Old May 6, 2008 | 12:45 PM
STS95T/A's Avatar
sorry but the 150mph cluster is a camaro cluster
let me know if you still want the hood
robbie
Old May 14, 2008 | 10:09 PM
94 Firehawk's Avatar
i want the lt1 starter
Old May 14, 2008 | 11:36 PM
96TAblur's Avatar
i want the subframe connectors. have they been previously installed? i will be in fort worth on friday getting some work done on my ta. can we meet on friday?
thanks,
mark
my email address is markcpa@windstream.net
my cell 940-631-6652
Old May 15, 2008 | 11:17 AM
STS95T/A's Avatar
pm's sent
robbie
importkiller94
Jan 17, 2015 09:03 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
jwright3SS
Jul 30, 2002 03:49 PM
Z284ever
22
Jul 27, 2002 04:12 PM
